NWGiles 10 Posted February 16, 2015 Posted February 16, 2015 (edited) Hi Folks I tried searching but couldn't find a definitive answer. If i fit a Quad tuner DVB-t2(uk) card to my PC housing MBS and set everything up. Would it be able to support 4 clients watching live tv or is it restricted to 1 watching and recording upto 3 other channels? hope this makes sense thanks Edited February 16, 2015 by NWGiles
Solution Spaceboy 2575 Posted February 16, 2015 Solution Posted February 16, 2015 you could have more than 4 clients watching tv as long as some of them are wacthing the same. you can stream or record up to 4 channels at a time. i have a dvbs2 quad card 1
NWGiles 10 Posted February 16, 2015 Author Posted February 16, 2015 thank you for replying that's great, a quad card it is thanks
