saintchelo 1 Posted February 14, 2015 Posted February 14, 2015 Hi I´m using MB 3.0.5518.2 (beta) and coverart 4.0.7.5 and when I try to go to Treatments tab in default profile to change the style of my midia, the treatment window is completely empty , without options, text, absolutely nothing. Only a blank window is opened. When I installed Coverart, everything worked perfectly but the next day the problem appeared. What´s happening ? Thnaks for all. 1
Happy2Play 9814 Posted February 14, 2015 Posted February 14, 2015 Try updating to MB 3.0.5518.3 and you should get Coverart 4.0.7.6 also.
saintchelo 1 Posted February 14, 2015 Author Posted February 14, 2015 Try updating to MB 3.0.5518.3 and you should get Coverart 4.0.7.6 also. Thanks but I updated to MB 3.0.5518.3 and the Covertart stiil in 4.0.7.5 version and the problem not solved. Stiil appear a blank window in Treatments tab.
ebr 16342 Posted February 14, 2015 Posted February 14, 2015 Have you done anything with custom css? It almost looks like it is trying to display the tabs at the top so large that only one fits.
saintchelo 1 Posted February 14, 2015 Author Posted February 14, 2015 Have you done anything with custom css? It almost looks like it is trying to display the tabs at the top so large that only one fits. No. I only use Coverart.
saintchelo 1 Posted February 14, 2015 Author Posted February 14, 2015 Have you done anything with custom css? It almost looks like it is trying to display the tabs at the top so large that only one fits. Hi. I notice that this problem occurs only in Chrome. In Firefox works fine. Thanks
