v0.550 Audio Themes Bug
cragjagged
Just letting everyone know that I've managed to confirm there is definitely a bug in v0.550 related to the Audio Themes that is causing navigation problems. This only seems to manifest after a video has been played and when moving from one item to another item that both have audio themes that are different. Once in the second item you'll get the audio theme for the second item but loose all navigational control, eventually the screensaver will activate and you won't be able to exit that either. Exiting back to the smart hub is the only way to get things working again.
Suggest disabling audio themes in the settings until a fix is issued
Edited by cragjagged
  • Like 1
