Tranquil 95 Posted February 12, 2015 Posted February 12, 2015 (edited) Hello Folks. I have a problem with the authentification by user process. This is what I send to the server: Content-Type: application/x-www-form-urlencoded Authorization=MediaBrowser UserId="FFFFFF-ad67-ffff-ffff-f629e3155721",Client="Android", Device="Samsung Galaxy SIII", DeviceId="12345", Version="1.0.0.0" Username=Tranquil Password=0a01153e3856d53a7b665be6b0b42effffffffff PasswordMd5=ab7d4316ffc25f1dec9211ffffffffff And I always get this response: { "ResponseStatus": { "Message" : "Invalid username or password entered.", "Errors" : [], "ErrorCode" : "SecurityException", "StackTrace": "[AuthenticateUserByName: 12.02.2015 14:33:52]:\n[REQUEST: {Username:Tranquil Password=0a01153e3856d53a7b665be6b0b42effffffffff PasswordMd5=ab7d4316ffc25f1dec9211ffffffffff}]\nMediaBrowser.Controller.Net.SecurityException: Invalid username or password entered.\r\n bei MediaBrowser.Server.Implementations.Library.UserManager.<AuthenticateUser>d__16.MoveNext()\r\n--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---\r\n bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n bei System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n bei MediaBrowser.Server.Implementations.Session.SessionManager.<AuthenticateNewSession>d__db.MoveNext()\r\n--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---\r\n bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n bei MediaBrowser.Api.UserService.<Post>d__17.MoveNext()" } } What I'm doing wrong? (SHA1 and MD5 are modified in this example but are correct in my source) Edit: Just to notice: I'm completely now to this so I'm just playing around a bit. :-) Edited February 12, 2015 by Tranquil
Tranquil 95 Posted February 12, 2015 Author Posted February 12, 2015 Hi Chef. Thanks for taking a look. You are right, the UserID does not exist at this early stage so I should leave it blank. Unfortunately I cant login a user anyway. It is still saying "wrong username or password". I'm also not able to login a user using the swagger-ui. If I fill the required fields I get a { "ResponseStatus": { "ErrorCode": "RequestBindingException", "Message": "Unable to bind request", "StackTrace": " bei ServiceStack.Host.RestHandler.CreateRequest(IRequest httpReq, IRestPath restPath)\r\n bei ServiceStack.Host.RestHandler.ProcessRequestAsync(IRequest httpReq, IResponse httpRes, String operationName)" } } My intention is, in a first step. port the API to my favorite language PureBasic and get deeper into Swagger-API support and maybe code some stuff for MBS.
ebr 16331 Posted February 12, 2015 Posted February 12, 2015 You haven't encoded your parameters properly. All of them are ending up in username. Username:Tranquil Password=0a01153e3856d53a7b665be6b0b42effffffffff PasswordMd5=ab7d4316ffc25f1dec9211ffffffffff 1
Tranquil 95 Posted February 12, 2015 Author Posted February 12, 2015 (edited) I thought this, what is the correct separator for this? EDIT: Got it! thanks for spotting on this! Edited February 12, 2015 by Tranquil
chef 3811 Posted February 12, 2015 Posted February 12, 2015 (edited) Nice Edited February 12, 2015 by chef 1
Tranquil 95 Posted February 12, 2015 Author Posted February 12, 2015 I think I now have everything I need to communicate with MBS correctly. First I thought I have to pass a Json structured body to the server.The parameters just have to be separated by a logical & symbol. I'm not a web developer so I have some lack of information here but google is a good friend. :-) If I have enough time at this weekend I will maybe create a module for PureBasic so that everyone can gain benefit of it in the PB community.
ebr 16331 Posted February 12, 2015 Posted February 12, 2015 It would be better to past post parameters as a json-encoded post body instead of url parameters.
