saitoh183 137 Posted February 11, 2015 Posted February 11, 2015 I was wondering how will the sync feature work from the clients? Like after you sync something via the server, how will you access it on the mobile client? Because right now when there is no server available, you cant really navigate offline in the client. Will clients also sync the user that was used to sync the content so you can login with it with no server available?
ebr 16336 Posted February 11, 2015 Posted February 11, 2015 Short answer is yes. We are currently working all of that out with the Windows 8.1 client and then we'll use that as a template for implementation on the others. 4
saitoh183 137 Posted February 11, 2015 Author Posted February 11, 2015 Short answer is yes. We are currently working all of that out with the Windows 8.1 client and then we'll use that as a template for implementation on the others. Thanks ebr
saitoh183 137 Posted February 12, 2015 Author Posted February 12, 2015 @@ebr I also forgot to ask, will the release of the client side for sync include a way to get the watch status back to the server? I think this would be a important to not have to do manually. Either something the server can do when it sees the client is back online or the client can do when it goes back online and can communicate with the server. 1
Beardyname 199 Posted February 12, 2015 Posted February 12, 2015 @@ebr I also forgot to ask, will the release of the client side for sync include a way to get the watch status back to the server? I think this would be a important to not have to do manually. Either something the server can do when it sees the client is back online or the client can do when it goes back online and can communicate with the server. yes
saitoh183 137 Posted February 12, 2015 Author Posted February 12, 2015 yes @@Beardyname Yes as in you agree? Yes, it is implemented?
Beardyname 199 Posted February 12, 2015 Posted February 12, 2015 @@Beardyname Yes as in you agree? Yes, it is implemented? it's implemented, now it's up to the individual apps! like 7 has done.
dwkev 1 Posted February 19, 2015 Posted February 19, 2015 Any idea when this feature will be available for ios? 1
saitoh183 137 Posted February 23, 2015 Author Posted February 23, 2015 (edited) So i just tried this out and it is working great. My only question is how does watched status get reported back to the server? ***Edit*** nvm, i saw the task go and show was updated. Edited February 23, 2015 by saitoh183
saitoh183 137 Posted February 23, 2015 Author Posted February 23, 2015 (edited) Would it be possible to get the option to auto remove (since there is a auto sync new content) a show if its mark as watched that we can set for particular shows so we dont have to manage show removal or is this in place already? Edited February 23, 2015 by saitoh183
Luke 42243 Posted February 23, 2015 Posted February 23, 2015 read the options in the slideout along with their associated help text 1
saitoh183 137 Posted February 23, 2015 Author Posted February 23, 2015 read the options in the slideout along with their associated help text yeah...i missed that piece of text...lol...Thanks Luke Only unwatched videos will be synced, and videos will be removed from the device as they are watched.
Florux 32 Posted February 24, 2015 Posted February 24, 2015 Would it be possible to introduce either a delay and/or a cleanup button to prevent shows from accidentally getting deleted upon finished when far away from home? Or is there already a way to manually remove all watched without automation?
saitoh183 137 Posted February 24, 2015 Author Posted February 24, 2015 Would it be possible to introduce either a delay and/or a cleanup button to prevent shows from accidentally getting deleted upon finished when far away from home? Or is there already a way to manually remove all watched without automation? shows are only removed when your online and the task is run from the server 1
thefirstofthe300 292 Posted February 24, 2015 Posted February 24, 2015 From the sound of it, sync is going to ROCK when the the mobile clients are finished. I like how you guys made sure you got it right with the first client before starting on the others. A much better way to do things when compared to how PLEX mass released and never bothered to get the bugs worked out before hand. 2
mediacowboy 438 Posted February 24, 2015 Posted February 24, 2015 So ready for the iOS client to support this. 1
Carlo 4561 Posted February 24, 2015 Posted February 24, 2015 From the sound of it, sync is going to ROCK when the the mobile clients are finished. I like how you guys made sure you got it right with the first client before starting on the others. A much better way to do things when compared to how PLEX mass released and never bothered to get the bugs worked out before hand. Amen to that. It's smarter in almost every way.
Florux 32 Posted February 24, 2015 Posted February 24, 2015 have you tried it? Sadly no - as I don't have a windows phone. My only "experience" is from translation work of the Android app, which clearly has led me in the wrong direction. Good to see it does not delete too aggressively.
NomadCF 15 Posted February 24, 2015 Posted February 24, 2015 Has any one considered a server to server sync or server to win7 client sync ?
akkidy 0 Posted February 25, 2015 Posted February 25, 2015 The sync is really a great feature and I'm so looking forward for more mobile devices support. I'm wondering if there will be some sort of device syncing permission that will be put in placed. For example, only allow users to sync to device that they have access and have logged on. Currently when all users have access to all devices, they can initiate a sync job to any devices. If I start limiting access to all devices, and select only the device belonging to each user, this blocks the users from syncing to devices not belonging to them, but becomes a problem for the users to log in with new devices. I'm still struggling in this area on how to allow new devices for users when they can't log in with the new device so it doesn't show up in the server for me to add to their allowed device access.
Luke 42243 Posted February 25, 2015 Posted February 25, 2015 The sync is really a great feature and I'm so looking forward for more mobile devices support. I'm wondering if there will be some sort of device syncing permission that will be put in placed. For example, only allow users to sync to device that they have access and have logged on. Currently when all users have access to all devices, they can initiate a sync job to any devices. If I start limiting access to all devices, and select only the device belonging to each user, this blocks the users from syncing to devices not belonging to them, but becomes a problem for the users to log in with new devices. I'm still struggling in this area on how to allow new devices for users when they can't log in with the new device so it doesn't show up in the server for me to add to their allowed device access. Yea an approval for new devices would be nice. until that happens, you just have to tell them to attempt to login with the new device and that should get it to show up in the list.
