GB3 issues
HI, haven't used GB since version 2 ( was too busy to go through config of GB3)
I started configuring GB3 but I ran into couple problems
1. I have about 20 wii and GC rams, but only iso's are shown , compressed games are not shown ( why is the rom filter excluded from the config, can it be added to GB3 configuration)
2. there is no way to add custom system, like it was possible in GB2, for example I want to add ZINC games, or Sega model 2...
Thanks
Redshirt
The intention is to make setup easier for users who aren't well versed in emulators.
Currently for Wii I have support for .iso, dol, ciso, wbfs, wad.
If you list the emulators I'm missing, and the extensions they use I'm willing to add them to the server config.
Thanks, Dolphin compressed iso is gcz so please add this extension, but would be really nice to add custom extension
Redshirt
The Saturn is already an available platform. The gcz extension will be in this weekends GB release.
Thanks, I did not noticed Saturn :)
please add option to add, more game (rom) extensions, I'm missing games in arcade (capcom, FBA, Sega system 2 ...) Sega Dreamcast, it will be easier for you, not needing to add extension every time someone needs some other extension , bin, cue, gcz, isz ...
