treason 11 Posted February 11, 2015 Posted February 11, 2015 (edited) So to follow up with the other discussion here: http://mediabrowser.tv/community/index.php?/blog/1/entry-172-media-browser-server-beta-305518-released/ I personally use IIS_Rewrite to serve up mediabrowser over http. In my webconfig I do: <rule name="mediabrowser" stopProcessing="true"> <match url="mediabrowser/(.*)" /> <conditions logicalGrouping="MatchAll" trackAllCaptures="false" /> <action type="Rewrite" url="http://192.168.1.110:8096/mediabrowser/{R:1}" /> </rule> Then IIS does my cert management, and runs other services in other subdirectories.. /service1 /service2 etc... The new server release busts that because 192.168.1.110:8096/mediabrowser/web/login.html requests resources outside of the /mediabrowser directory (check net tab in firebug) 192.168.1.110:8096/System/Info/Public 192.168.1.110:8096/Branding/Css 192.168.1.110:8096/users are all dead urls because they break out of the subdirectory Also 192.168.1.110:8096/mediabrowser/ does a 302 redirect to 192.168.1.110:8096/web/login.html when IMO it should respect the original path and redirect to 192.168.1.110:8096/mediabrowser/web/login.html Edited February 11, 2015 by treason
treason 11 Posted February 11, 2015 Author Posted February 11, 2015 Beautiful. You are fast as hell with these updates, thanks
Cerothen 98 Posted February 12, 2015 Posted February 12, 2015 I can also confirm that 3.0.5518.3 seems to solve this problem. Things are working well again. Thanks!
Cerothen 98 Posted February 12, 2015 Posted February 12, 2015 (edited) Beautiful. You are fast as hell with these updates, thanks Good Evening Treason, I have been having an issue where nonlocal clients cant seem to play mp4 content when through the reverse proxy. I have confirmed the IIS has the appropriate MIME types (that I can think of) but from what I can tell it only applies to files in my library that are MP4. Thought I would check if you have the same problems. Edited February 12, 2015 by Cerothen
pir8radio 1313 Posted January 6, 2016 Posted January 6, 2016 (edited) @@Cerothen probably the same issue I was having: http://emby.media/community/index.php?/topic/29405-reverse-proxy-mp4-wont-play-need-some-input-please-was-working/ Oops old thread.. Edited January 6, 2016 by pir8radio
