Remote Control Links
Hi, newbee question.
I'm trying to set up my remote (Harmony 650 for what its worth).
I was hoping to be able to have some links straight to (MB) Movies and (MB) TV in the same way as I have for TV Channels, etc where I have mapped a key in keyboard.xml to ActivateWindow(TVChannels), what should it be for MB sections?
Hope this makes sense.
FWIW I'm running Titan Beta & MB Beta
marcelveldt
You can use the so called window properties for that...
For a complete list of properties see here:
https://github.com/MediaBrowser/MediaBrowser.Kodi.SkinHelper/blob/master/README.txt
I'm not sure if this will work with the kayboard.xml commands though but you can give it a try.
If you want to open "alle movies" for example set this as the action:
$INFO[Window(Home).Property(MediaBrowser.std.movies.0.path)]
Please note the ".path" at the end. You can place any of the properties from the list but maybe first try with the one above if this even works with commands.
Guest
