CBers 7554 Posted February 2, 2015 Posted February 2, 2015 (edited) I posted the F8000 details above. @@DaN confirmed they were the same for the F7500. I'll update your file tomorrow. . Edited February 2, 2015 by CBers
cragjagged 44 Posted February 2, 2015 Posted February 2, 2015 I've dropped in the E series info from the ES7000 manual
chessdragon136 677 Posted February 2, 2015 Author Posted February 2, 2015 Great! I am making the assumption that all series of a tv can play the same files but I don't think that's too bad. Must be better than the current system
cragjagged 44 Posted February 2, 2015 Posted February 2, 2015 There may be some oddities with firmware versions introducing newer features (probably only relevant for F series onwards), and some of the newer models in the D and E series may have more support than the original D and E series models. Taking the approach you are though should work, there may just be a of fringe cases where the app is missing a couple of rarer formats in the compatibility matrix
chessdragon136 677 Posted February 3, 2015 Author Posted February 3, 2015 (edited) Yeah its never going to be perfect unless its coded on a per model per firmware basis, and that's never going to happen! Thanks to all those who helped, I think its done now Edited February 3, 2015 by chessdragon136
SamES 1084 Posted February 3, 2015 Posted February 3, 2015 @@chessdragon136, I've added a document for ES8000 in your OneDrive folder. It has a few extra formats not in @@cragjagged's list. I've also included music and image formats for future reference. 1
