Teddy 100 Posted November 3, 2013 Posted November 3, 2013 I was using MB3 since time but after last updates almost every new movie has not backdrops or folder but has overview, actors and ART Disc.logo... I did a scratch installation from O.S and downloaded the Server and MB3 classic but remains the backdrops problem. Even I downloaded the DEV version for both and from Movies I found the new "browse online Images" and I can choose the backdrops and download them and then are showed in MB3. Then the issue seems MB3 or server not fetch automatically the backdrops. I attach the server and MB3 logs. Thanks in advance MBClassic-3112013e57b7a9ec4e44622aead69b143163b99.log server-63519105473.log
yardameus 221 Posted November 3, 2013 Posted November 3, 2013 I noticed this last night as well, added a few movies and everything was added but the poster and the backdrop.
Solution Luke 42287 Posted November 3, 2013 Solution Posted November 3, 2013 It's my mistake and will be fixed in the next release. Because we now combine fanart, i made the tvdb and tmdb fetchers a little pickier so that they would exclude images that are lower resolution than what fanart would give you. This way I figured if you got nothing from the tmdb, you'd get it from fanart. But in some cases that results in not getting images at all, so that will be fixed. 2
yardameus 221 Posted November 3, 2013 Posted November 3, 2013 Odd that it's not downloading even if fanart has it.
Teddy 100 Posted November 3, 2013 Author Posted November 3, 2013 Thanks a lot Luke. I was getting fool. So I'll await for next release. A question please cause problem it's Server or MB3 classic? Regards
Luke 42287 Posted November 3, 2013 Posted November 3, 2013 it's server-related. if it's not downloading fanart then it's something else, but chances are it's fixed already because in the process of developing manual image downloads I've uncovered several issues and fixed them. 3
