berrick 30 Posted February 1, 2015 Posted February 1, 2015 Latest Beta's installed Only running server, coverart & advanced intro's When I click shows via IE11 I get a mix of treatments for the shows I have in mediabrowser, for example the default no treatment image and thumb. When I click episodes I get default no treatment image, thumb and episode. Metadata manager appears to show the correct folder structure. I have same problem if I create a CA profile just for TV. Any suggestions, TY
Solution ebr 16343 Posted February 1, 2015 Solution Posted February 1, 2015 I'm going to need to see some pictures of what you are seeing and how you've setup CA but be sure you are not looking at backdrops in some of those areas. CA will never treat backdrops. 1
berrick 30 Posted February 1, 2015 Author Posted February 1, 2015 Cheers ebr, Some issues where cleared by performing a refresh on the metadata BUT the missing link for those still not being treated as I wanted was the lack of a thumbs.jpg in the relevant folder, just backdrops. A couple of quick question re the indicator overlays as they aren't appearing on all images. what can stop the info from being displayed Can this option display MP3 info like bit rate
ebr 16343 Posted February 1, 2015 Posted February 1, 2015 1 - the inability to determine the proper info to display (like there is no media information for that item) 2 - no, it will only show the items indicated in the options (video codec, resolution, audio codec and aspect ratio)
