ginjaninja 605 Posted January 31, 2015 Posted January 31, 2015 (edited) Version 3.0.5509.223 This Film with this folder name is not identified.. A local .nfo has localtitle tag populated as St. Vincent (2014) Further use of identify function, without manual changes, does not detect. The Following Work as manual ammedments within the identify function... St. Vincent - without the year St Vincent (2014) - without the full stop St. Vincent 2014 - without the year in brackets %Movietitle% (%Year%) ...has always been a good way to get 100% detection...so is this a bug/an opportunity to improve? or am i out of step with naming convention and need to change...? I have OMDB First and TMDB second as metadate fetchers... edit noted server version Edited January 31, 2015 by ginjaninja
Latchmor 584 Posted January 31, 2015 Posted January 31, 2015 Hi, not sure what version of server you are on but I can confirm the dev server is doing this too. Cheers
ginjaninja 605 Posted January 31, 2015 Author Posted January 31, 2015 Hi, not sure what version of server you are on but I can confirm the dev server is doing this too. Cheers thnks for reproducing..yes i am on dev build
CBers 7541 Posted January 31, 2015 Posted January 31, 2015 Works here OK. Use themoviedb ID of 239563 in MEDIA BROWSER. I also used IMDB ID of tt2170593.
ginjaninja 605 Posted January 31, 2015 Author Posted January 31, 2015 Works here OK. Use themoviedb ID of 239563 in MEDIA BROWSER. I also used IMDB ID of tt2170593. yup for aadvanced users they can force a recognition..but if the casual user is king..the automatic fetch is where the problem is..
snazy2000 344 Posted January 31, 2015 Posted January 31, 2015 It auto fetched for me few days ago (running dev)
CBers 7541 Posted January 31, 2015 Posted January 31, 2015 It auto fetched for me few days ago (running dev) It did for me as well, also running dev, but wanted to re-fetch which was why I used the IDENTIFY option.
ginjaninja 605 Posted February 1, 2015 Author Posted February 1, 2015 (edited) for those that it auto fetched for are you using a folder\file structure of \\SERVER\Share\St. Vincent (2014)\St. Vincent (2014).mkv or some thing else what is your metadata order for movies? is the identify function working.. it seems unlikely ...like for like its not working for me but working for you...there must be a difference and were not comparing like for like. edit.. i think the identify routine must be slightly different for the identify routing post successful identification..or a server update has affected. once identified.... St. Vincent (2014) identified ok when using identify function a 2nd time... edit a freshly created \\SERVER\Share\St. Vincent (2014)\St. Vincent (2014).mkv is auto fetched ok for me today.....maybe the primary fetchers was offline and the other has an issue...who knows....its working today.. Edited February 1, 2015 by ginjaninja
CBers 7541 Posted February 1, 2015 Posted February 1, 2015 We're there any errors in the MBS log when you first added the movie. My structure is the same as your's. I don't use nfo files. My metadata fetchers are tmdb then the open movie database. Same for image fetchers.
ginjaninja 605 Posted February 1, 2015 Author Posted February 1, 2015 (edited) We're there any errors in the MBS log when you first added the movie. My structure is the same as your's. I don't use nfo files. My metadata fetchers are tmdb then the open movie database. Same for image fetchers. wasnt looking out on first ingestion..so no logs thanks for confirming your settings.. i have omdb first then tmdb.. wonder what latchmoor finds..? @@Latchmor Edited February 1, 2015 by ginjaninja
ebr 16307 Posted February 1, 2015 Posted February 1, 2015 Is it possible that, when it was first added, a stub nfo file came over with it? That would stop us from even trying to fetch metadata.
Latchmor 584 Posted February 1, 2015 Posted February 1, 2015 Hi Guys, Yesterday my log showed this, 2015-01-31 16:57:23.8246 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=St++Vincent+(2014)&language=en 2015-01-31 16:57:23.9636 Debug - App: MovieDbProvider returned no metadata for \\ED-WORK\F\Test\Films\St. Vincent (2014)\St. Vincent (2014).mkv 2015-01-31 16:57:23.9636 Debug - App: Running OmdbItemProvider for \\ED-WORK\F\Test\Films\St. Vincent (2014)\St. Vincent (2014).mkv 2015-01-31 16:57:23.9726 Info - App: MovieDbProvider: Finding id for item: St. Vincent (2014) 2015-01-31 16:57:23.9726 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=St.+Vincent+(2014)&language=en 2015-01-31 16:57:24.1076 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=St++Vincent+(2014)&language=en 2015-01-31 16:57:24.2496 Debug - App: OmdbItemProvider returned no metadata for \\ED-WORK\F\Test\Films\St. Vincent (2014)\St. Vincent (2014).mkv Nothing else appeared in the folder. Identify also found nothing unless I removed full stop. I left it blank (as it was a dummy movie anyway) to see if subsequent scans would find it. Still no metadata today but now, after seeing this thread again, if I go to Identify it finds it without removing full stop so not sure what changed. Cheers 1
Solution ebr 16307 Posted February 1, 2015 Solution Posted February 1, 2015 Probably, this was just a search issue on the provider end and they fixed it while we were trying to figure it out. 1
Latchmor 584 Posted February 1, 2015 Posted February 1, 2015 (edited) Probably, this was just a search issue on the provider end and they fixed it while we were trying to figure it out. I'm guessing you are correct. I just added a dummy St. Trinians (2007).mkv as another full stop test and the first scan found everything as normal Edited February 1, 2015 by Latchmor
CBers 7541 Posted February 1, 2015 Posted February 1, 2015 I'm guessing you are correct. I just added a dummy St. Trinians (2007).mkv as another full stop test and the first scan found everything as normal You mean you haven't already got that in your collection? 1
Latchmor 584 Posted February 1, 2015 Posted February 1, 2015 You mean you haven't already got that in your collection? Ha ha, the old ones are better
CBers 7541 Posted February 1, 2015 Posted February 1, 2015 Ha ha, the old ones are better They are, but they don't have a young Gemma Arterton in them
Latchmor 584 Posted February 1, 2015 Posted February 1, 2015 They are, but they don't have a young Gemma Arterton in them True. I'm glad you mentioned that and didn't pick on my age instead... 1
CBers 7541 Posted February 1, 2015 Posted February 1, 2015 (edited) True. I'm glad you mentioned that and didn't pick on my age instead...I wouldn't, as I'm older than you . Edited February 1, 2015 by CBers
