Popeye2468 44 Posted November 3, 2013 Posted November 3, 2013 When I run scan media library I get this error Unhandled exception: The specified path, file name, or both are too long. the fully qualified name must be less than 260 characters, and the directory name must be less than 248 characters I have attatched the log file unhandled_6b2010d5-8c33-4ffc-ac18-343862c0c37a.txt
Sven 136 Posted November 3, 2013 Posted November 3, 2013 What is your path? You have probably many sub folders? So the name will be to long....
ebr 16354 Posted November 3, 2013 Posted November 3, 2013 That is a limitation of the underlying system. It usually occurs with bad metadata for actors or with very deeply nested music folders. @@Luke - can we add a log entry for the name that is causing this exception to make it easier to find?
Luke 42287 Posted November 3, 2013 Posted November 3, 2013 This is already fixed for the next server release. Well, fixed in the sense that the server won't crash on it. I'll add the path to the logging
