bhelm1 1 Posted September 3, 2020 Posted September 3, 2020 I pulled down the zip file with the folder structure and imported my video files, however the metadata doesn't seem to be picking up anything from TMDB. I tried to manually identify and I'm not getting any artwork. Thoughts on what I'm missing? Thanks for sharing your work!
yaksplat 68 Posted September 3, 2020 Posted September 3, 2020 7 hours ago, bhelm1 said: I pulled down the zip file with the folder structure and imported my video files, however the metadata doesn't seem to be picking up anything from TMDB. I tried to manually identify and I'm not getting any artwork. Thoughts on what I'm missing? Thanks for sharing your work! Did you set up the library as movies?
Carlo 4561 Posted September 3, 2020 Posted September 3, 2020 Hi guys, Thought I'd jump in as well. I setup all my Looney Tunes as TV Shows under "Looney Tunes" with year seasons such as "Season 1929". To me this was a much cleaner way and treats the episodes pretty much how you would see them on TV and allows NEXT UP and other TV functionality to shine through that you would lose using Movies. Sure it might be a bit harder setup but worth it IMHO. Carlo
yaksplat 68 Posted September 3, 2020 Posted September 3, 2020 58 minutes ago, cayars said: Hi guys, Thought I'd jump in as well. I setup all my Looney Tunes as TV Shows under "Looney Tunes" with year seasons such as "Season 1929". To me this was a much cleaner way and treats the episodes pretty much how you would see them on TV and allows NEXT UP and other TV functionality to shine through that you would lose using Movies. Sure it might be a bit harder setup but worth it IMHO. Carlo The problem is that this was never a series. They were all shorts, treated as movies. So what's your solution to only watch bugs bunny? Or what if you want the one with the alien baby and have no idea what year it was?
Carlo 4561 Posted September 3, 2020 Posted September 3, 2020 Yea, I totally agree it wasn't really a series and was a bunch of what we would call shorts these days. Looney Tunes is sort of in limbo land. I admit there is no "best way" to handle these. There does seem to be two different solutions that people make work. I don't advocate one way over the other. I just personally went the TV Show way and put in the "hurt" to identify each "short" and then matched them up with the metadata provider for naming. This way I get NEXT UP type functionality and it would be a good way to have them if using the Virtual TV plugin (I think). This is just something that needs a bit of brute force to make it work, one way or the other!
bhelm1 1 Posted September 3, 2020 Posted September 3, 2020 11 hours ago, yaksplat said: Did you set up the library as movies? I at first set it up as TV Shows but just tried as movies and now I get, "no items found"?
Happy2Play 9800 Posted September 3, 2020 Posted September 3, 2020 17 minutes ago, bhelm1 said: I at first set it up as TV Shows but just tried as movies and now I get, "no items found"? Can you go over exactly what you have done.
bhelm1 1 Posted September 3, 2020 Posted September 3, 2020 1 minute ago, Happy2Play said: Can you go over exactly what you have done. I have ripped disc by episode, downloaded zip file containing folder structure and nfo files, placed the m4v files in this structure and added the folder path to Emby, first as TV Shows and this worked but the artwork did not show up. I then removed the TV Show setup and re-added as Movies but now it shows "no items found" after scanning library files.
Happy2Play 9800 Posted September 3, 2020 Posted September 3, 2020 2 minutes ago, bhelm1 said: TV Shows and this worked but the artwork did not show up Using the zip provided in the topic has to be Movies. I haven't tested but in no way work as tv as all the provider ids are wrong in the provided nfo file. Now as Movies not every item will have a image. Best you will get is Screen grabs. Small sample from Tweety. Easiest to show from folder view. 8 minutes ago, bhelm1 said: re-added as Movies but now it shows "no items found" after scanning library files. Did you by change add a subfolder library path that is part of another library? But many need to see all libraries you have configure, as no library can contain a subfolder of any other library.
bhelm1 1 Posted September 3, 2020 Posted September 3, 2020 6 minutes ago, Happy2Play said: Using the zip provided in the topic has to be Movies. I haven't tested but in no way work as tv as all the provider ids are wrong in the provided nfo file. Now as Movies not every item will have a image. Best you will get is Screen grabs. Small sample from Tweety. Easiest to show from folder view. Did you by change add a subfolder library path that is part of another library? But many need to see all libraries you have configure, as no library can contain a subfolder of any other library. I think I got it, I was adding the root folder that contained all the show folders not the individual show folders Bugs Bunny, Elmer Fudd, etc. It picked up and is now showing the shows, so I'm assuming this is the correct way to add these. Thanks for your help!
Happy2Play 9800 Posted September 3, 2020 Posted September 3, 2020 1 minute ago, bhelm1 said: I think I got it, I was adding the root folder that contained all the show folders not the individual show folders Bugs Bunny, Elmer Fudd, etc. It picked up and is now showing the shows, so I'm assuming this is the correct way to add these. Thanks for your help! Not knowing your other configured Movie Libraries I personally would not point to the specific folders. In my example I dropped the Tweety folder directly in my Movies library and showed you via Folder view the results.
yaksplat 68 Posted September 3, 2020 Posted September 3, 2020 You should just be able to point to the Looney tunes folder. That's how I have it and it catches everything.
bhelm1 1 Posted September 4, 2020 Posted September 4, 2020 1 minute ago, yaksplat said: You should just be able to point to the Looney tunes folder. That's how I have it and it catches everything. That is how I started but had added them as TV shows, but got no artwork. I then deleted that setup and add them as Movies, but no go.. when I do that I get nothing, even selecting folder view shows no folders. When I added as TV Shows I at least got something? The folder is not part of any other library.
Carlo 4561 Posted September 4, 2020 Posted September 4, 2020 Hi, What's the md127 for? What do the season and files look like in this directory?
bhelm1 1 Posted September 4, 2020 Posted September 4, 2020 Just now, cayars said: Hi, What's the md127 for? What do the season and files look like in this directory? MD127 is the name of my Hard Drive array, inside of the I have 3 folders, TV Shows, Videos (Movies) and Looney Tunes.
Happy2Play 9800 Posted September 4, 2020 Posted September 4, 2020 @bhelm1 The end question would be do you have a library already pointing to /mnt/md127? Can you show a screenshot of Dashboard-Library. 21 minutes ago, yaksplat said: You should just be able to point to the Looney tunes folder. That's how I have it and it catches everything. That depend on if the folder is already part of another library.
bhelm1 1 Posted September 4, 2020 Posted September 4, 2020 7 minutes ago, Happy2Play said: @bhelm1 The end question would be do you have a library already pointing to /mnt/md127? Can you show a screenshot of Dashboard-Library. That depend on if the folder is already part of another library. Setup:
Happy2Play 9800 Posted September 4, 2020 Posted September 4, 2020 Just now, bhelm1 said: Setup: That is correct. Do you see anything in the folders tab? Only other thing I can think of would be permissions. Can you post a server log.
Carlo 4561 Posted September 4, 2020 Posted September 4, 2020 I would say that's not good. If you mount to /mnt/md127/Looney Tunes you lost the "Looney Tunes" folder. Instead I'd try something like /mnt/md127/shorts as the mount point with /mnt/md127/shorts/Looney Tunes as the folder under the mount point.
bhelm1 1 Posted September 4, 2020 Posted September 4, 2020 3 minutes ago, Happy2Play said: That is correct. Do you see anything in the folders tab? Only other thing I can think of would be permissions. Can you post a server log. No, nothing listed. Log attached. embyserver.txt
Happy2Play 9800 Posted September 4, 2020 Posted September 4, 2020 Don't know the exact meaning but issues within that path. System.IO.FileNotFoundException: Could not find file 2020-09-03 02:30:11.211 Error LibraryMonitor: Error in Directory watcher for: /mnt/md127/Looney Tunes *** Error Report *** Version: 4.4.3.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 5.4.0.45 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/mnt/md127/Looney Tunes/Peppy Le Pew/Little Beau Pep� (1952)'. File name: '/mnt/md127/Looney Tunes/Peppy Le Pew/Little Beau Pep� (1952)' Source: TargetSite: No Stack Trace Available
Carlo 4561 Posted September 4, 2020 Posted September 4, 2020 I'd wager it's the special character in the name after "Pep".
bhelm1 1 Posted September 4, 2020 Posted September 4, 2020 Ok I deleted the folder structure, added a folder for Shorts and then added just the Bugs Bunny folder into Short. That worked, so I then added all of the remaining folder in and rescanned and seems to be okay now. I did combed through and removed those random symbols as cayars noted afterwards just to be safe. Thanks everyone for your help! 1
Happy2Play 9800 Posted September 4, 2020 Posted September 4, 2020 2 minutes ago, cayars said: I'd wager it's the special character in the name after "Pep". It might be OS related as I am not seeing this issue in Windows testing this one. System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/mnt/md127/Looney Tunes/Other/The Fighting 69�th (1941)'.
