Jimbo960 0 Posted January 24, 2015 Posted January 24, 2015 (edited) I have a problem. I have 2 machines with 2 server programs running on my lan. the reason for 2 servers is that trying to stream through one server to access a library on the other machine results in poor playback. on my rokus I have no problem seeing both servers and selecting them to get good playback. but when I try web access I can only see one server. even if I'm on the other machine locally. the web address link will not link me to that 2nd server. it's only good for the other one. any ideas? and yes I've tried using different ports. Edited January 24, 2015 by Jimbo960
Luke 42184 Posted January 24, 2015 Posted January 24, 2015 one server installation is unaware of the other one. so you need to give them both separate ports, bookmark both web client url's and access them separately. you can also look into using the Connect feature which will help manage switching between them.
mouseware 9 Posted January 26, 2015 Posted January 26, 2015 Why not share your data on one "server" and map it on the other. That way you only need one "server" with it's local data and the mapped data from the other box?
