ginjaninja 605 Posted January 24, 2015 Posted January 24, 2015 (edited) 3.0.5502.3522 Specials (S00E01 tested in particular) have a propensity to appear too soon in the next up calculation. Assuming, for testing, saved changes to the attributes - airs before/after season/episode, are reread after a library scan I have an S00E01 which i can not get to NOT appear 1st for a completely unwatched show under next up...The correct location should be at end of season 1. But S00E01 stubbornly shows up in next up. Possibly related to this http://mediabrowser.tv/community/index.php?/topic/13324-special-watched-status-is-affecting-series-next-up-presence/?hl=%2Bspecials+%2Bnext&do=findComment&comment=150785 From TVDB Wiki airsafter_season An unsigned integer indicating the season number this episode comes after. This field is only available for special episodes. Can be null. airsbefore_episode An unsigned integer indicating the episode number this special episode airs before. Must be used in conjunction with airsbefore_season, do not with airsafter_season. This field is only available for special episodes. Can be null. airsbefore_season An unsigned integer indicating the season number this special episode airs before. Should be used in conjunction with airsbefore_episode for exact placement. This field is only available for special episodes. Can be null. FWIW my expectations as a user would be Specials with [airs before season]=blank,[airs after season]=blank, [airs before episode]=blank - would never appear on next up...they are special interest episodes that dont form part of the flow of watching eg. making of show type specials, as opposed to a Christmas Special which should be marked to appear in the order of watching...as it forms part of the story. Specials with either [airs before season] or [airs after season] - would appear on next up in the order of [Airs after Season]=1 would Come before [Airs Before Season]=2 so Season 1 Episodes < Airs After Season 1 Episodes < Airs Before Season 2 Episodes Airs before episode is a bit of a mystery as to what is being referenced to..to avoid ambiguity it presumably means for eg Airs Before Season=2, Airs Before Episode=5.... of all the specials that are tagged as such ( [air before season]=2), the position of this special is AFTER those specials with [Airs Before Season]=2 and with [Airs Before Episode]<5, and BEFORE specials with [Airs Before Season]=2 and with [Airs Before Episode]>5. It should not be allowed for two episodes to have the same Airs Before Season/Episode Pair. It also shouldnt be possible for Airs before Episode to be populated and Airs before Season to not be populated, but if this was the case, then I think MB3 should not consider the episode part of next up in any case (The metadata needs correcting on tvdb). Edited January 24, 2015 by ginjaninja
