jasonwilliams 37 Posted January 24, 2015 Posted January 24, 2015 This is just an awesome project. I'm not a developer. I'm not rich. What is the best way I can help? 2
Beardyname 199 Posted January 24, 2015 Posted January 24, 2015 Helping out around the forums, or if you are not a native English speaker check out the translation project Other than that spread the word and have a good time! 1
thefirstofthe300 292 Posted January 24, 2015 Posted January 24, 2015 Bug reporting and alpha/beta testing is extremely helpful too. I will warn you though that alpha/beta testing will eventually cause something in your setup to break so please do not use those branches as your production box unless you don't mind things breaking. 1
Luke 42243 Posted January 24, 2015 Posted January 24, 2015 This is just an awesome project. I'm not a developer. I'm not rich. What is the best way I can help? Welcome! You can help translate, or tell us what skills you do have that you feel would be helpful. You can also help spread the word and recruit other new developers.
