WarrenH 16 Posted January 24, 2015 Posted January 24, 2015 My Samsung an H Series. Followed instructions no problem by logging in as develop and password. Found developer IP setting and inserted IP per photo. I have the Samsung keyboard and smart remote. To move between IP address boxes I use the left mouse click on the keyboard. However, I then can't move to the OK button to submit the new IP address as I can't navigate to the button. I've tried about all keyboard keys. The smart mouse won't move to the OK button either, and seems to be focussed on the apps behind the dialog box. Anyone else who's managed this please help. Thanks
chessdragon136 677 Posted January 24, 2015 Posted January 24, 2015 Do you not have a standard remote? I can't speak for the others so can't be of much help. If not, reboot the tv and try again? I can't say I've heard of anyone with this issue since starting the app. Sorry I'm not of more use
bertbert72 14 Posted January 24, 2015 Posted January 24, 2015 Try pressing the Keypad button on the smart remote and clicking on OK there. Seems to work on my H model. 1
WarrenH 16 Posted January 24, 2015 Author Posted January 24, 2015 Bert - got it to work as described, thanks all for your efforts 1
WarrenH 16 Posted January 24, 2015 Author Posted January 24, 2015 Maybe to add, I think the BT keyboard may have been interfering with operation of the remote
