bxsteez 3 Posted January 23, 2015 Posted January 23, 2015 I remember there use to be a way to show the available shortcuts in MBC but I can't find that option anymore. Is there a wiki for shortcuts because I couldn't find any. Seems like it would be a useful addition. I'm trying to find a shortcut for info in particular.
Solution ebr 16334 Posted January 25, 2015 Solution Posted January 25, 2015 Shortcut? You mean button remote presses or keyboard combinations? Most of them are displayed in Chocolate when you hover on the tool menu (unless you turned the legend off). 1
bxsteez 3 Posted January 26, 2015 Author Posted January 26, 2015 Shortcut? You mean button remote presses or keyboard combinations? Most of them are displayed in Chocolate when you hover on the tool menu (unless you turned the legend off). I meant keyboard combinations but I did not realize it was theme specific. I had been using chocolate for so long then switched xenon and couldn't find it anymore. Since it is theme specific maybe there should be a wiki page for it since some themers are not including it.
