Joulester 0 Posted January 23, 2015 Posted January 23, 2015 Hi guys! I have looked and didn't find anything about this. So my problem is this. with kodi/xbmc you can choose an option "play using" when you right click on a movie and you can stream to an other device using dlna/upnp. I would like to do this but with the mediabrowser plugin for kodi. Is there a solution for this or something that is worth taking a look on?
bluemonkey07 590 Posted January 23, 2015 Posted January 23, 2015 My first question is why would you like to do this? Media browser has allot of remote play to options why do you need to do it thru kodi?
Joulester 0 Posted January 24, 2015 Author Posted January 24, 2015 Becuse I have problem with playing movies that are packed in .rar files and the only solution to that are either unpack or play with Kodi. and im a big fan of kodi to so i would like to have that feature . Do you think that is possible?
bluemonkey07 590 Posted January 24, 2015 Posted January 24, 2015 Yes but why use kodi to send to another device? Any native media browser client can do this
Joulester 0 Posted January 25, 2015 Author Posted January 25, 2015 So you mean that I only send it to an other device and not streaming it to an other deceive? then I think I need an other solution on how to stream rar files to a smart tv. thanks for fast answer
Deihmos 170 Posted January 25, 2015 Posted January 25, 2015 Wouldn't it just be easier to extract the video from rar? Doesn't your client automatically do this? Playing video in rar is something that was done over 10 years ago and I can't imagine why anyone would still do it.
Joulester 0 Posted January 25, 2015 Author Posted January 25, 2015 I think it´s much easier to store it this way. Do you say that there is no way to do it as I tried to explain?
Luke 42238 Posted January 25, 2015 Posted January 25, 2015 There aren't many players that understand media within archive files. That puts you in the position you're in now of not being able to play anything until you can convince your media player of choice to support it. So yes I think he's suggesting some practicality which is good advice.
Joulester 0 Posted January 25, 2015 Author Posted January 25, 2015 Thank you! then i got an answer to my question and will move on with my problems. do you guys know a auto unpacking program?
