pki 0 Posted January 21, 2015 Posted January 21, 2015 Hi i am trying to make a transition to Mediabrowser 3 but the results are very poor. I am using Kodi with Mediabrowser for kodi and mediabrowser android app. 1)When i try to see a picture from kodi picture doesnt show 2)When i try to cast a video/music/photo from the android app to kodi nothing happens. Here are my logs kodi.log server-63557474578.txt
elcabong 48 Posted January 21, 2015 Posted January 21, 2015 can you play any videos directly from browsing the Kodi interface? if not, then you may have an issue of Kodi not being able to see your media. you might need to setup path substitution in your Mediabrowser server.
pki 0 Posted January 23, 2015 Author Posted January 23, 2015 can you play any videos directly from browsing the Kodi interface? if not, then you may have an issue of Kodi not being able to see your media. you might need to setup path substitution in your Mediabrowser server. directly i can play the movies and music and i can see the library from the android app the problem is when i try to cast them from android app to kodi(nothing happens).
