KarterJK 35 Posted January 18, 2015 Posted January 18, 2015 Now it is nice to have the little green check mark on watched items, but is there a way to reset those?
Solution Happy2Play 9800 Posted January 18, 2015 Solution Posted January 18, 2015 Sure you can uncheck each item or from folder level. 1
osak00006 12 Posted September 8, 2016 Posted September 8, 2016 Sure you can uncheck each item or from folder level. Is it possible to do this in bulk, for the entire library? Essentially, resetting all watched statuses -- including resume status -- back to unwatched/start from beginning?
Happy2Play 9800 Posted September 8, 2016 Posted September 8, 2016 Is it possible to do this in bulk, for the entire library? Essentially, resetting all watched statuses -- including resume status -- back to unwatched/start from beginning? Yes, use the multi-select option on Home screen and select all the libraries you want, the click the three dot menu in top right and select 'Mark as Unplayed". (Open Multi-Select left click and hold)
osak00006 12 Posted September 8, 2016 Posted September 8, 2016 Yes, use the multi-select option on Home screen and select all the libraries you want, the click the three dot menu in top right and select 'Mark as Unplayed". (Open Multi-Select left click and hold) Thanks. That addressed played/unplayed. How about resume status?
Happy2Play 9800 Posted September 8, 2016 Posted September 8, 2016 I know using multi-select and marking as watched clears the setting, so you may have to toggle them watched then unwatched.
osak00006 12 Posted September 9, 2016 Posted September 9, 2016 Worked. Thanks again!! Sent from my HTC6535LVW using Tapatalk
