DarkKniyt (John) 6 Posted January 15, 2015 Posted January 15, 2015 A recent update (assuming it was a Server Update) changed the way Multiple-Level Folders display. To explain what I mean....... For Example: I have 5 Batman TV-Series. Each Series has multiple Seasons. I placed the 5 Series under a "Collections" Folder. So the folder structure would look like the following: -BATMAN COLLECTION -Batman Adventures -Season 1 -Season 2 -Batman Beyond -Season 1 -Season 2 -Batman Adventures -Season 1 -Season 2 etc....... SO, when scrolling through my TV Series the Top-Level folder I see is BATMAN COLLECTION. I select this folder and I see Batman Adventure, Batman Beyond, Batman Adventures, etc... If I select Batman Adventures I used to see Season 1, Season 2, Season 3 etc... Then when selecting a Season I would see each episode. That was before, now when I select a Series (Batman Adventures) I see ALL Episodes and not each Season displayed. I haven't made any setting changes in quite some time, so I am assuming this is due to an update?? Any help would be appreciated! Thanks - John.
Solution Happy2Play 9806 Posted January 15, 2015 Solution Posted January 15, 2015 (edited) You need to go to Metadata Manager and change the content type from inherit to TV for Batman Collection and run library scan. Look at Star Trek example. Edited January 15, 2015 by Happy2Play 1
DarkKniyt (John) 6 Posted January 15, 2015 Author Posted January 15, 2015 It Worked! Thank you very much!
mwhitford 0 Posted January 12, 2020 Posted January 12, 2020 Hi there I have a similar problem. I've grouped my TV shows by type/country (Comedy - UK, Drama -US, etc) and for some of my folder they are now being detected as TV shows themselves rather than parent folders. https://emby.media/community/index.php?/topic/67894-how-to-set-content-types-of-sub-folders-for-mixed-contents/ It looks like this potential fix no longer works. is there a way I can still get the folders behaving as intended?
Luke 42216 Posted January 12, 2020 Posted January 12, 2020 Hi there I have a similar problem. I've grouped my TV shows by type/country (Comedy - UK, Drama -US, etc) and for some of my folder they are now being detected as TV shows themselves rather than parent folders. https://emby.media/community/index.php?/topic/67894-how-to-set-content-types-of-sub-folders-for-mixed-contents/ It looks like this potential fix no longer works. is there a way I can still get the folders behaving as intended? Hi, can you please go over a specific example? thanks.
mwhitford 0 Posted January 12, 2020 Posted January 12, 2020 https://github.com/MediaBrowser/Wiki/wiki/TV-naming the recommended option is to create a TV media folder and add the sub-folder locations instead of the top level folder I'm going to give this a go first. Hopefully it's an easy fix
