clm000 0 Posted January 12, 2015 Posted January 12, 2015 Hi, Thanks for the great Roku client and MB3 in general. I'm having an issue with WOL and the Roku client and have a few questions. 1) Is WOL coded into the Roku client (I'm using v 1.78 now)? I read conflicting statements about WOL support in the Roku client in other forum posts 2) If it is, what should I see in the logs generated by the client relative to WOL? 3) WOL works using Media Browser Theater (MBT) running on a laptop waking the MB3 server running as service on a desktop on the same LAN. WOL also works from many other apps and scripts I use all the time, so I'm sure the MB3 server is capable and configured correctly to wake from a WOL magic packet. 4) I assume your sending a magic packet for WOL, is that correct? As opposed to ping or some other "pattern match" packet 5) Am I missing some configuration step to get WOL working? I have sideloaded the app to generate logs and an example of the issue is below (I don't see anything relative to WOL in the log): ------ Running ------ --1.78 Anamorphic support: true Server.info: listening on 0.0.0.0:8324 Using broadcast address 10.68.68.255 Send To Address: 10.68.68.255:7359 / 10.68.68.255:7359 Cancel UDP Broadcast Found 0 servers Connect returned 0 servers Creating server data cache Found string in the registry: {"a1d90fbe6f7400e5d7663049cd848bd0":{"AccessToken":"bba7f6b930b74a3986875b76ec6a4aa8","UserId":"0130cfdac20bb8c7147cfed6ffaf0e39","RemoteAddress":"http://xxx.yyyy.com:8096","LastAccess":"1421039815","Name":"PC-C","LocalAddress":"http://10.68.68.34:8096","id":"a1d90fbe6f7400e5d7663049cd848bd0"}} Parsed as: roAssociativeArray connectionManagerGetServers returning 1 servers connectToServers called with 1 servers Attempting to connect to http://10.68.68.34:8096/mediabrowser/system/info/public?format=json Failed Response with Error: -7 Failed to get Server Info Attempting to connect to http://xxx.yyyy.com:8096/mediabrowser/system/info/public?format=json Failed Response with Error: -7 Failed to get Server Info connectInitial returned State of ConnectSignIn connectInitial returned ConnectionMode of Manual Processing ConnectionResult State of ConnectSignIn Entered CreateScreenForItem Not sure what to do with breadcrumbs on screen type: roCodeRegistrationScreen Pushing screen 1 onto view controller stack - ConnectSignIn Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=73098&deviceId=1GU451103739 Poll result: {"Id":"51108","Pin":"73098","DeviceId":"1GU451103739","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=73098&deviceId=1GU451103739 Poll result: {"Id":"51108","Pin":"73098","DeviceId":"1GU451103739","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=73098&deviceId=1GU451103739 Poll result: {"Id":"51108","Pin":"73098","DeviceId":"1GU451103739","IsExpired":false,"IsConfirmed":false,"AccessToken":""}
Luke 42241 Posted January 13, 2015 Posted January 13, 2015 After you connect once it will record the servers Mac address. Try connecting over then exit the app, shut down mbs and try to connect. When the local connection fails it should wol then try again
clm000 0 Posted January 13, 2015 Author Posted January 13, 2015 I have connected to the server multiple times in the past, yet it still will not wake it from sleeping. Should I be able to see anything in the log above?
