ginjaninja 605 Posted January 12, 2015 Posted January 12, 2015 (edited) Version 3.0.5490.2 1.78 roku i presume this problem is related to avidemux..as that was the significant factor but have not yet tried to reproduce. What i have seen before is mb3 getting confused after changing existing content. history played tv episode -:sound out of sync used avidemux to sync audio 200ms (copy streams)... overwrote poor sync file with good sync file playing tv episode on webclient or roku..immediately bugs out...playback fine from explorer using mpchc or wmp. refreshed episode in web client - playback continues to bug out copied good sync file to a mixed content folder and rescanned library. playing good sync file from mixed content folder is fine ...so some sort of hiccup in the file scanning engine for existing content which has been modified i thought... 2nd attempt to play good sync file from mixed content folder....bugs out and continues to bug out.. .....so something else/in addition is going on...is the avidemux operation corrupting the file from mb3 pov even though mpchc is fine...but then why did the avidemux modified file play first time in new location. logs from trying to play the file on roku Getting metadata for Id 0809f2cfdb89df7823a1d2edaecd9567 Media item container: mp4 Media item video codec: h264 Media item audio codec: aac Media item subtitles: invalid Media item stereo codec: aac Media item surround codec: invalid Secondary audio stream selected: false Setting video springboard screen content Showing video springboard screen Connection[87046859].info: accepted connection @192.168.4.130:64619 Request[2].info: POST '/mediabrowser/message/Ping' Reply[30].info: Sent 164 [0-163/164] Reply[30].info: source buf is empty Reply[30].info: Sent-1 [0--2/0] Connection[87046859].info: send reply peer closed @192.168.4.130:64619 2015-01-12 12:00:55.5832 Error - HttpResultFactory: Error streaming data *** Error Report *** Version: 3.0.5488.1547 Command line: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. System.IO.IOException at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at SocketHttpListener.Net.ResponseStream.InternalWrite(Byte[] buffer, Int32 offset, Int32 count) at SocketHttpListener.Net.ResponseStream.Write(Byte[] buffer, Int32 offset, Int32 count) at System.IO.Stream.InternalCopyTo(Stream destination, Int32 bufferSize) at System.IO.Stream.CopyTo(Stream destination) at MediaBrowser.Server.Implementations.HttpServer.StreamWriter.WriteToInternal(Stream responseStream) InnerException: System.Net.Sockets.SocketException An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) 2015-01-12 12:00:55.5832 Error - HttpAsyncTaskHandler: Error occured while Processing Request: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. *** Error Report *** Version: 3.0.5488.1547 Command line: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. System.IO.IOException at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at SocketHttpListener.Net.ResponseStream.InternalWrite(Byte[] buffer, Int32 offset, Int32 count) at SocketHttpListener.Net.ResponseStream.Write(Byte[] buffer, Int32 offset, Int32 count) at ServiceStack.Formats.HtmlFormat.SerializeToStream(IRequest request, Object response, IResponse httpRes) at ServiceStack.HttpResponseExtensionsInternal.WriteErrorToResponse(IResponse httpRes, IRequest httpReq, String contentType, String operationName, String errorMessage, Exception ex, Int32 statusCode) at ServiceStack.ServiceStackHost.OnUncaughtException(IRequest httpReq, IResponse httpRes, String operationName, Exception ex) at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse(IResponse response, Object result, ResponseSerializerDelegate defaultAction, IRequest request, Byte[] bodyPrefix, Byte[] bodySuffix) at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse(IResponse httpRes, IRequest httpReq, Object result, Byte[] bodyPrefix, Byte[] bodySuffix) at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse(IResponse httpRes, IRequest httpReq, Object result) at ServiceStack.Host.RestHandler.<>c__DisplayClass5.<ProcessRequestAsync>b__0(Object response) at ServiceStack.Host.Handlers.ServiceStackHandlerBase.HandleResponse(Object response, Func`2 callback, Func`2 errorCallback) InnerException: System.Net.Sockets.SocketException An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) 2015-01-12 12:00:55.5832 Debug - HttpServer: HTTP Response 500 to 192.168.4.143. Response time: 61.5078 ms. Url: http://192.168.4.130:8096/mediabrowser/Videos/0809f2cfdb89df7823a1d2edaecd9567/stream?static=true&mediaSourceId=0809f2cfdb89df7823a1d2edaecd9567 2015-01-12 12:00:55.5832 Error - HttpResultFactory: Error streaming data *** Error Report *** Version: 3.0.5488.1547 Command line: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. System.IO.IOException at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at SocketHttpListener.Net.ResponseStream.InternalWrite(Byte[] buffer, Int32 offset, Int32 count) at SocketHttpListener.Net.ResponseStream.Write(Byte[] buffer, Int32 offset, Int32 count) at System.IO.Stream.InternalCopyTo(Stream destination, Int32 bufferSize) at System.IO.Stream.CopyTo(Stream destination) at MediaBrowser.Server.Implementations.HttpServer.StreamWriter.WriteToInternal(Stream responseStream) InnerException: System.Net.Sockets.SocketException An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) 2015-01-12 12:00:55.5832 Error - HttpAsyncTaskHandler: Error occured while Processing Request: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. *** Error Report *** Version: 3.0.5488.1547 Command line: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Nicholas Bird\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. System.IO.IOException at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at SocketHttpListener.Net.ResponseStream.InternalWrite(Byte[] buffer, Int32 offset, Int32 count) at SocketHttpListener.Net.ResponseStream.Write(Byte[] buffer, Int32 offset, Int32 count) at ServiceStack.Formats.HtmlFormat.SerializeToStream(IRequest request, Object response, IResponse httpRes) at ServiceStack.HttpResponseExtensionsInternal.WriteErrorToResponse(IResponse httpRes, IRequest httpReq, String contentType, String operationName, String errorMessage, Exception ex, Int32 statusCode) at ServiceStack.ServiceStackHost.OnUncaughtException(IRequest httpReq, IResponse httpRes, String operationName, Exception ex) at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse(IResponse response, Object result, ResponseSerializerDelegate defaultAction, IRequest request, Byte[] bodyPrefix, Byte[] bodySuffix) at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse(IResponse httpRes, IRequest httpReq, Object result, Byte[] bodyPrefix, Byte[] bodySuffix) at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse(IResponse httpRes, IRequest httpReq, Object result) at ServiceStack.Host.RestHandler.<>c__DisplayClass5.<ProcessRequestAsync>b__0(Object response) at ServiceStack.Host.Handlers.ServiceStackHandlerBase.HandleResponse(Object response, Func`2 callback, Func`2 errorCallback) InnerException: System.Net.Sockets.SocketException An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) transcode log..from i think the first working time in the mixed content folder... subsequent playback requests are not creating more transcode log files.. https://dl.dropboxusercontent.com/u/84611964/transcode-fd25ee01-9c3f-479b-a8d8-c2965f3dda35.txt Edited January 12, 2015 by ginjaninja
ginjaninja 605 Posted January 12, 2015 Author Posted January 12, 2015 (edited) starting to doubt myself now..... I resynced the original file using MP4v2 muxer rather than MP4 muxer, and im having no such problems.... maybe i misrecollected the symptoms/history and its just the avidemux MP4 muxer is not compatable with MB3..or now im not even sure i didnt use the avi muxer default.....how embarassing...ill get my facts straight next time.. edit.. doesnt seem to be anything wrong with either mp4 or mp4v2 muxer...everthing seems fine...and mb3 seems robust in handling me replacing exisitng files....false alarm i guess. Edited January 12, 2015 by ginjaninja
