jbsdma 0 Posted February 19, 2016 Posted February 19, 2016 SO ... it seems I missed the "mixed content" setting for the library so there's no metadata scraping. For the other noobs out there this seems to get a folder view navigation to work ... but I don't know if this is quite the right way going about this???
joho500 1 Posted March 27, 2016 Posted March 27, 2016 Having the same problem that top-level folders are seen as content. See images below. I would like to be able to have real folder view with metadata for artists, albums and tracks. Another, corresponding problem is that I don't get a folder view in BubbleUPnP anymore. I hope both options can be solved? Cheers, Joost In browser: Folder tree is like this:
Luke 42266 Posted April 13, 2016 Posted April 13, 2016 Newer releases of the server have a folders tab under music.
joho500 1 Posted April 14, 2016 Posted April 14, 2016 Hi Luke, I'm on 3.0.5913.0. The screenshot above shows the folder tab ('Mappen' in Dutch). Any idea on how to solve this? And the problem that I don't get a folder view in an upnp/dlna app? Cheers, Joost
joho500 1 Posted April 15, 2016 Posted April 15, 2016 When I select for instance the folders 70s, 80s and Blues (with the music icon) not the underlying artists folders are displayed but this:
Luke 42266 Posted April 15, 2016 Posted April 15, 2016 Thanks, I've resolved this for the next release.
joho500 1 Posted April 18, 2016 Posted April 18, 2016 Thanks. Looking forward to it. And do you have a solution for my other remark: no folders option in the dlna apps. I use BubbleUPnP and tried also MediaHouse which both have that problem.
ginjaninja 605 Posted April 18, 2016 Posted April 18, 2016 its a useful alternative that on an organised collection (music library\artist\albums), folder view shows real album artist albums only (rather than muddled up with compilations and other albums featuring the artist). Hopefully this organisation will come to the database view :-)
joho500 1 Posted April 19, 2016 Posted April 19, 2016 Thanks, I've resolved this for the next release. It works. Thanks for your work. it just hasn't been added yet. Hopefully it will be in the near future?
joho500 1 Posted August 13, 2016 Posted August 13, 2016 (edited) Hi Luke, The problem described below is back again. I'm running 3.0.6060.0 Joost When I select for instance the folders 70s, 80s and Blues (with the music icon) not the underlying artists folders are displayed but this: Edited August 13, 2016 by joho500
joho500 1 Posted August 27, 2016 Posted August 27, 2016 Hi Luke, Working again on 3.0.6200.0. Thank you. Joost
lunadmin 0 Posted September 2, 2016 Posted September 2, 2016 Same Problem with new Version Version 3.0.6400.0 in Folder View with Videos, Music ...
Luke 42266 Posted September 2, 2016 Posted September 2, 2016 Same Problem with new Version Version 3.0.6400.0 in Folder View with Videos, Music ... Hi there, did you see post #39? Thanks!
lunadmin 0 Posted September 2, 2016 Posted September 2, 2016 (edited) Yes i have seen that it should worked in 3.0.6200.0 but it doesn't work on the new version. Take some subfolder as a movie/music file, without possibility for change. Edited September 2, 2016 by lunadmin
Luke 42266 Posted September 2, 2016 Posted September 2, 2016 Hi, can you describe your issue in a little more detail? Perhaps with screenshot(s)? Thanks!
lunadmin 0 Posted September 2, 2016 Posted September 2, 2016 Yes it's really simple. I make a repo and use the folder view there is ## Action subfolder 1 - filmfolder 1 - filmfolder 2 - filmfolder 3 - filmfolder 4 .... ## Comedy subfolder 2 - filmfolder 1 - filmfolder 2 - filmfolder 3 - filmfolder 4 .... ## Fantasy subfolder 3 - filmfolder 1 - filmfolder 2 - filmfolder 3 - filmfolder 4 .... ## Horror subfolder 4 - filmfolder 1 - filmfolder 2 - filmfolder 3 - filmfolder 4 .... For the most it is working, but in case for the genre folder named ## Horror it doesn't display any filmfolder, in this case he makes a filmentry for the Rocky Horror Picture Show. You can delete and change the information but it will never browseable. Tried to rename it like ## Horror Films, then it links directly to one of the filmfolder. Can't find why. It is really strange that there is no option to make a folder manually as subfolder but anyway. With Music, it doesn't work completly as music, then it appears like the screens already posted with all music files as one. So i have to use mixed content, and then in the drectory view some subfolders appears as songs like with the #horror folder.
Luke 42266 Posted September 2, 2016 Posted September 2, 2016 Can you show us what it looks like in the emby web app? thanks.
lunadmin 0 Posted September 2, 2016 Posted September 2, 2016 In the Videos it happens like that, in this case, all films will shown as additional content and original subfolder is pointing to any folder - not with the content described.
lunadmin 0 Posted September 2, 2016 Posted September 2, 2016 i Have seen that Folders with the name "This is the name (DVD)" will break emby and make a lot of mysterious malfunctions. Like that i've described. In the Explorer view there shouldn't be a problem with any name. The folder view is also the same as i choose mixed content and in both the same problem occurs.
ebr 16347 Posted September 3, 2016 Posted September 3, 2016 Does your "Horror" folder have any video files directly within it?
Luke 42266 Posted September 3, 2016 Posted September 3, 2016 can you show us what the folders look like?
