oldschool 16 Posted January 22, 2015 Author Posted January 22, 2015 So, I think I've narrowed it down to the Genre Cleaner plugin. Whenever I install that plugin, after a few hours, my CPU usage will spike to 99%. After uninstalling it (I've done this twice now), my server will go back to normal operation and will not top out my CPU.
ebr 16354 Posted January 22, 2015 Posted January 22, 2015 Interesting. I don't know if the interface will allow it but did you maybe setup some sort of circular reference? Like mapping genre A to B and then B back to A again?
oldschool 16 Posted January 22, 2015 Author Posted January 22, 2015 I didn't really do anything with it. I installed it, but I never configured it. I really don't know how to use it, but I just installed it and was going to get to it later. As far as my library, I use MCM and it sets up my genres for me, so it is possible there is something like that, but I don't know.
oldschool 16 Posted January 22, 2015 Author Posted January 22, 2015 And let me clarify, when my CPU spikes, I can't do anything with MB3, so I have to shut down the program and restart it in order to uninstall the plugin. I could be wrong singling out that plugin, but so far it looks like the culprit.
