t.andre 69 Posted September 24, 2015 Author Posted September 24, 2015 Can't find the update but I'll wait till it comes and let you know if it works. Updated Emby and Plugin but still no luck same error Can you post your log file ? Thanks
AlwinHummels 134 Posted September 24, 2015 Posted September 24, 2015 (edited) Can you post your log file ? Thanks Yes of course sorry I didn't that before Log.txt Edited September 24, 2015 by AlwinHummels
Guest solomalee Posted September 24, 2015 Posted September 24, 2015 Hi, Try to update to the last version of dvblink 1.0.5743.35858 Cheers Where is this new version to be found. The plug in library only lists 1.0.5741.39244 Thanks Solo
t.andre 69 Posted September 24, 2015 Author Posted September 24, 2015 It's strange I ave published 2 days ago. Go to Scheduled Tasks and launch check for plugin updates.
Guest solomalee Posted September 24, 2015 Posted September 24, 2015 Done the plug in sync, also restarted the server...only that older version visible I'm afraid. Solo
AlwinHummels 134 Posted September 24, 2015 Posted September 24, 2015 (edited) Where is this new version to be found. The plug in library only lists 1.0.5741.39244 Thanks Solo You have to update Emby server first. I had the same problem but after update the server I could update the plugin, but unfortunately still no luck and same error. Log.txt Edited September 24, 2015 by AlwinHummels
t.andre 69 Posted September 24, 2015 Author Posted September 24, 2015 (edited) Try again I have changed the required server version to 3.0.5724.4 Edited September 24, 2015 by t.andre
Guest solomalee Posted September 24, 2015 Posted September 24, 2015 Try again I have changed the required server version to 3.0.5724.4 OK, now I see it...not sure about the server update (I'm on the latest "official release" as far as I can tell (Version 3.0.5724.4) Sorry...same error still exists Status: Unavailable (No connection to DVBLink.)
t.andre 69 Posted September 24, 2015 Author Posted September 24, 2015 OK, now I see it...not sure about the server update (I'm on the latest "official release" as far as I can tell (Version 3.0.5724.4) Sorry...same error still exists Status: Unavailable (No connection to DVBLink.) Can you show me the log file please ?
Guest solomalee Posted September 24, 2015 Posted September 24, 2015 Can you show me the log file please ? Here you go. Just tried again with OS X Firewall switched off - same result. Solo server-63578730613.txt
AlwinHummels 134 Posted September 26, 2015 Posted September 26, 2015 Updated my dvblink server to 5.5.0 build 11984 Now I see Tuners Naam Bron Status Programma Clients Externe diensten DVBLink 5.5.0 Up to date! Status: Ok But still no guide and live TV and a very strange log please help. Log.txt
t.andre 69 Posted September 26, 2015 Author Posted September 26, 2015 Hi, I have published a new version Please can you try and tell me if everything is OK ? Cheers.
hhb97b 11 Posted September 27, 2015 Posted September 27, 2015 Hi I still getting the error 2015-09-27 13:33:41.2359 Info - App: [DVBLink] Start GetStatusInfoAsync 2015-09-27 13:33:41.2359 Info - App: [DVBLink] Server Address : http://htpc:8100/cs/ 2015-09-27 13:33:41.2359 Info - App: [DVBLink] Start InitiateSession 2015-09-27 13:33:41.2359 Info - App: [DVBLink] Server version : 1.0.5748.22720 2015-09-27 13:33:41.2359 Info - App: [DVBLink] Start Initialize Async 2015-09-27 13:33:41.2419 Error - App: [DVBLink] It's not possible to Ensure a connection to the DVBLink Server *** Error Report *** Version: 3.0.5747.18286 Command line: C:\Users\Kim Andersen\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kim Andersen\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kim Andersen\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Server Status : STATUS_INVALID_DATA System.InvalidOperationException at MediaBrowser.Plugins.DVBLink.LiveTvService.<EnsureConnectionAsync>d__56.MoveNext() InnerException: System.Net.WebException The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.WebClient.GetWebResponse(WebRequest request, IAsyncResult result) at System.Net.WebClient.DownloadBitsResponseCallback(IAsyncResult result) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Plugins.DVBLink.DVBLinkClient.<HttpClientPostAsync>d__50.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Plugins.DVBLink.DVBLinkClient.<GetResponse>d__44`1.MoveNext() I have tried the url http://htpc:8100/cs/ in my firefox browser and I'm getting the following error: "The authentication flow was cancelled.". I'm not having any authentication set up. I running version 5.5 build 11858 of dvblink and your plugin version is 1.0.5748.22720
hhb97b 11 Posted September 27, 2015 Posted September 27, 2015 (edited) Hi I have resolved my problem. I upgrade the dvblink server to build 11984 and emby can now connect However the version attribute is now failing with: "Status: Unavailable (Server Status : STATUS_INVALID_DATA)" Edited September 27, 2015 by hhb97b
AlwinHummels 134 Posted September 27, 2015 Posted September 27, 2015 Sorry but can't get it work server-63578963602.txt
t.andre 69 Posted September 27, 2015 Author Posted September 27, 2015 it's strange because in the log everything is ok. connection to server : OK channels ok
bluc 21 Posted September 28, 2015 Posted September 28, 2015 Add another with non working live tv . However the link http://htpc:8100/cs/ works fine for me... Sent from my SM-T705Y using Tapatalk
AlwinHummels 134 Posted September 29, 2015 Posted September 29, 2015 I reinstall my server setup from strath now all works fine thanks for all help
hhb97b 11 Posted October 9, 2015 Posted October 9, 2015 (edited) Hi I have resolved my problem. I upgrade the dvblink server to build 11984 and emby can now connect However the version attribute is now failing with: "Status: Unavailable (Server Status : STATUS_INVALID_DATA)" My problem has come back 2015-10-09 21:18:28.6492 Info - App: [DVBLink] Start Initialize Async 2015-10-09 21:18:28.6852 Error - App: [DVBLink] It's not possible to Ensure a connection to the DVBLink Server *** Error Report *** Version: 3.0.5759.20136 Command line: C:\Users\Kim Andersen\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Kim Andersen\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Kim Andersen\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Server Status : STATUS_INVALID_DATA System.InvalidOperationException at MediaBrowser.Plugins.DVBLink.LiveTvService.<EnsureConnectionAsync>d__56.MoveNext() InnerException: System.Net.WebException The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.WebClient.GetWebResponse(WebRequest request, IAsyncResult result) at System.Net.WebClient.DownloadBitsResponseCallback(IAsyncResult result) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Plugins.DVBLink.DVBLinkClient.<HttpClientPostAsync>d__50.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Plugins.DVBLink.DVBLinkClient.<GetResponse>d__44`1.MoveNext() Edited October 9, 2015 by hhb97b
Luke 42243 Posted October 9, 2015 Posted October 9, 2015 My problem has come back In order to best get help, it's best to be a good community citizen and supply useful info that can be used to assist you. For example, are you certain that both Emby and Dvb are running at the same time? That may sound like a really trivial thing, but you wouldn't be believe how many times we've seen this with all of the tv plugins that require external software. And since it depends on Dvb, you should make sure Dvb is functioning normally and tell us what you did to verify that. Finally, if none of that helps, you should see here: http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/
Spaceboy 2573 Posted October 10, 2015 Posted October 10, 2015 hd channels do not start for me anymore in the webclient, i get an error message as below. tuners are available. watching the monitoring tab in the dvblink config shows nothing starts. on the android app the audio starts but there is no video. also i need to repeat that live tv through emby and the dvblink plugin is pretty inconsistent all over. but i've posted about this many times and you haven't acknowledged it. its often slow and often doesn't load at all. i'm happy to try and help troubleshoot. thankfully emby for kodi and the very sound dvblink plugin for kodi are doing the job hello, although i have seen significant improvement in the speed and reliability of live tv recently i still have this problem and cannot play any hd channels. i've tried all of the new options but they do not seem to make any difference
hhb97b 11 Posted October 11, 2015 Posted October 11, 2015 (edited) figure out the problem. The plugin only works with ip-address not hostname(and probably not dns) in the input box. You should add some validation to check the input or support hostname/dns. Also if you change it from ip to the hostname the old connection is being used in the connection checker, giving the impression that it is working but after a restart it fails. Edited October 11, 2015 by hhb97b
t.andre 69 Posted October 12, 2015 Author Posted October 12, 2015 Hi, hhb97b I confirm that the plugin only works with IP address for now. I will update the first page with this information.
t.andre 69 Posted October 12, 2015 Author Posted October 12, 2015 hello, although i have seen significant improvement in the speed and reliability of live tv recently i still have this problem and cannot play any hd channels. i've tried all of the new options but they do not seem to make any difference Hi, Can you post the logs from emby and the transcoder if you have one ? With that I can analyse to see what is the problem. I'm in Switzerland and notice that some hd channels doesn't wok correctly for me to in DVBLink.
Spaceboy 2573 Posted October 12, 2015 Posted October 12, 2015 (edited) Hi I posted the logs when I originally reported the problem, I assume these will still be valid? Attached to post 176 ta Also these used to work but now do not, in the web client I get the error message I posted, but in the android TV app I get sound but no video so it seems there is an incompatible video stream? Hope this helps! Edited October 12, 2015 by Spaceboy
