Luke 42243 Posted August 21, 2019 Posted August 21, 2019 Yes that is correct. Did you do what he suggested?
muppets4 24 Posted August 21, 2019 Posted August 21, 2019 (edited) Yes that is correct. Did you do what he suggested? No I did not. I cannot select the right EPG. Only xmltv and schedules direct. Not the plugin. And there is no button for refreshing the guide when there is no EPG source selected. In the past I had to configure LiveTV options under services. But there is no tab anymore. (Emby btw tells me to fill in the service under the tab!) Edited August 21, 2019 by muppets4
pünktchen 1411 Posted August 21, 2019 Posted August 21, 2019 ... And there is no button for refreshing the guide when there is no EPG source selected. In the past I had to configure LiveTV options under services. But there is no tab anymore. (Emby btw tells me to fill in the service under the tab!)Just run the Refresh Guide under Dashboard -> Tasks.
muppets4 24 Posted August 22, 2019 Posted August 22, 2019 Just run the Refresh Guide under Dashboard -> Tasks. I will try. Not at his home now. Thanks.
ich777 11 Posted December 3, 2019 Posted December 3, 2019 Got a little problem running this plugin. I install the plugin, restart the server go again into the plugins settings, enter the ip and the login credentials, also enable the TV Mosaic server click on save on the bottom of the settings and nothing happens. I'm using the docker image of Emby v4.3.0.30 and also TV Mosaic v1.0.0 Build 17707. I think it has something with the plugin itself to do since it doesn't create a configuration file in ../plugins/configurations I also tried to install another plugin (DVBViewer) to see if something is wrong with my installation but it creates a configuration file and also it saves everything fine also nothing in the logs if i click on save on the plugin settings page of TV Mosaic. Can somebody help me out please...
EODCrafter 181 Posted December 3, 2019 Posted December 3, 2019 Got a little problem running this plugin. I install the plugin, restart the server go again into the plugins settings, enter the ip and the login credentials, also enable the TV Mosaic server click on save on the bottom of the settings and nothing happens. I'm using the docker image of Emby v4.3.0.30 and also TV Mosaic v1.0.0 Build 17707. I think it has something with the plugin itself to do since it doesn't create a configuration file in ../plugins/configurations I also tried to install another plugin (DVBViewer) to see if something is wrong with my installation but it creates a configuration file and also it saves everything fine also nothing in the logs if i click on save on the plugin settings page of TV Mosaic. Can somebody help me out please... Did you Mount that folder in the Docker Run? TBH don't know anything about Docker, but it seems logical.
WEHA 0 Posted December 3, 2019 Posted December 3, 2019 I have the same issue in Windows. I tried installing a previous version but it installed the latest regardless. I think it started when I disabled the "Enable TVMosaic" option because I had some issues with TVMosaic itself. After that was resolved I wanted to turn it on again but nothing happened. The original config file is still there and says enabled = true. Changing this file does nothing, also renaming it does not create a new file (even when reinstalling the plugin)
Luke 42243 Posted December 3, 2019 Posted December 3, 2019 @t.andre please check the plugin config page for possible script errors. Thanks. 1
ich777 11 Posted December 3, 2019 Posted December 3, 2019 Did you Mount that folder in the Docker Run? TBH don't know anything about Docker, but it seems logical. I don't understand... The whole folder for Emby is mounted because it's the workdirectory. Btw @t.andre the DVBLink plugin does the same like the TV Mosaic plugin, also doesn't save the settings nor does it create configuration file in the configuration directory. The original config file is still there and says enabled = true. Changing this file does nothing, also renaming it does not create a new file (even when reinstalling the plugin) Firstly i got also a very old config file for the plugin in the config directory but since the plugin wasn't working i thought i delete it and the plugin will create a new one but that's not the case. Exectly the same as you say in your post.
t.andre 69 Posted December 3, 2019 Author Posted December 3, 2019 Hi, I will try to check that tomorrow or this weekend. Cheers 1
EODCrafter 181 Posted December 4, 2019 Posted December 4, 2019 I don't understand... The whole folder for Emby is mounted because it's the workdirectory. Btw @t.andre the DVBLink plugin does the same like the TV Mosaic plugin, also doesn't save the settings nor does it create configuration file in the configuration directory. Firstly i got also a very old config file for the plugin in the config directory but since the plugin wasn't working i thought i delete it and the plugin will create a new one but that's not the case. Exectly the same as you say in your post. Yea, like I said, don't know anything about Docker...Sry
t.andre 69 Posted December 8, 2019 Author Posted December 8, 2019 Hi, The plugin is updated. - Version : 1.8.8 (2019.12.08) * Fix save settings Cheers
Siutsch 9 Posted December 9, 2019 Posted December 9, 2019 (edited) Hi, The plugin is updated. - Version : 1.8.8 (2019.12.08) * Fix save settings Cheers Hi @t.andre Doesn't work here. Emby 4.3.0.30, TVMosaic Server at Synology NAS (newest), plugin 1.8.8. I can use TV since months without problems, so I don't have to change the settings. But: "Enable TVMosaic server" is always unchecked, if I enable that (an other settings, like "Use server Authorization" and save that, after looking again at the plugin settings, everything is still unchecked. So TV works, but I still can't change something. And there is no Server status (all empty). Siutsch. Edited December 9, 2019 by Siutsch
Luke 42243 Posted December 11, 2019 Posted December 11, 2019 Did you make sure to attach the information requested in how to report a problem? https://emby.media/community/index.php?/topic/790-how-to-report-a-problem/?view=getnewpost Thanks.
t.andre 69 Posted December 12, 2019 Author Posted December 12, 2019 Nothing ... ?Can you please send me the log? Envoyé de mon LYA-L29 en utilisant Tapatalk
QDivision 42 Posted December 18, 2019 Posted December 18, 2019 But: "Enable TVMosaic server" is always unchecked, if I enable that (an other settings, like "Use server Authorization" and save that, after looking again at the plugin settings, everything is still unchecked. So TV works, but I still can't change something. I have the exact same problem. Looking at the plugin settings page all the checkboxes are unticked (like it's not reading the current setting) however everything seems to work as normal i.e. I have tv logos even though the 'Use Server Logos' is unticked and the plugin works even though 'Enable TVMosaic server' is unticked. See screenshot.
Luke 42243 Posted December 18, 2019 Posted December 18, 2019 Can you supply the browser debug console contents for t.andre to review? Thanks.
QDivision 42 Posted December 18, 2019 Posted December 18, 2019 (edited) see attached debug.txt consolelog.txt Edited December 18, 2019 by DIY-Sensei
watcha 0 Posted December 23, 2019 Posted December 23, 2019 (edited) Just installed TVMosaic and the plugin in Emby as well. I cannot use it, because the tick 'enabled' is always unticked. When i click on Live TV, emby hangs at all. Can anyone tell me something about the channel switch speed? is it faster than TV Headend?I use a SatIP Server as backend. Thank you! EDIT: Is it correct, that TVMosaic does not handle XMLTV on its own? I have to download it?! Edited December 23, 2019 by watcha
Luke 42243 Posted December 23, 2019 Posted December 23, 2019 Just installed TVMosaic and the plugin in Emby as well. I cannot use it, because the tick 'enabled' is always unticked. When i click on Live TV, emby hangs at all. Can anyone tell me something about the channel switch speed? is it faster than TV Headend? I use a SatIP Server as backend. Thank you! EDIT: Is it correct, that TVMosaic does not handle XMLTV on its own? I have to download it?! Hi there, please attach the emby server log. Thanks.
QDivision 42 Posted January 16, 2020 Posted January 16, 2020 I have the exact same problem. Looking at the plugin settings page all the checkboxes are unticked (like it's not reading the current setting) however everything seems to work as normal i.e. I have tv logos even though the 'Use Server Logos' is unticked and the plugin works even though 'Enable TVMosaic server' is unticked. See screenshot. see attached Hi any update on this issue?
