Luke 42243 Posted April 9, 2019 Posted April 9, 2019 Hi. Same problem. I'm using Emby 4.1.0.23 together with TVMosaic@@synology NAS. TV doesn't work with browser (Firefox), and it doesn't work with Android App (Beta) too. It doesn't work over local access (IP), nor from outside. I see only the spinner and there are no files in transcoding folder. Perhaps that has something to do with new Emby Beta version? Please see how to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
Siutsch 9 Posted April 18, 2019 Posted April 18, 2019 Since new stable version 4.1.0.26 is out now and I still have the problems, that I cant start live tv, what's with the other TVMosaic users here? Is it only me and user newby that have these problems? @t.andreHave you tried new Emby version 4.1.0.xx with last TVMosaic plugin (1.8.5.0)? Thanks.
t.andre 69 Posted April 18, 2019 Author Posted April 18, 2019 Hi I didn't tryed yet but this weekend I will correct it. Cheers Envoyé de mon LYA-L29 en utilisant Tapatalk 2
QDivision 42 Posted April 20, 2019 Posted April 20, 2019 (edited) Hi, same issue here, latest emby server installed 4.1.0.26 and now live tv doesn't play and there are no items under the recordings folder. Edited April 20, 2019 by DIY-Sensei
Luke 42243 Posted April 20, 2019 Posted April 20, 2019 Please see how to report a media playback issue: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
QDivision 42 Posted April 20, 2019 Posted April 20, 2019 attached is the screenshot of the recordings page that is empty when it shouldn't be. Also attached is the log of trying to play an item in live tv, however i can't see any log entry for it. When i press on play all i get is the loading spinner and nothing else Log.txt
Luke 42243 Posted April 20, 2019 Posted April 20, 2019 OK looks like the plugin just needs an update. thanks.
t.andre 69 Posted April 22, 2019 Author Posted April 22, 2019 Hi, The plugin is updated. - Version : 1.8.6 (2019.04.22) * Fix Live The recording fix comming next. Cheers 2
t.andre 69 Posted April 22, 2019 Author Posted April 22, 2019 Hi, To refresh the list of recordings please run scheduled task Refresh internet channels Please let me know if it's working.
QDivision 42 Posted April 22, 2019 Posted April 22, 2019 Hi, The live tv is working again now and the recordings are showing again. However the recordings section from the home screen section does not work properly. It shows a random category (which is wrong) and the going into 'tv shows' then '8 out of 10 cats' its empty but if i go into the category 'news and documentary' it shows there. Secondly there seems to be a lot of clicking to get to the actual recordings from the home screen section, I would expect to just click on recordings then have all the shows there rather than having to click on further cub categories. (This works correctly if you go into 'Live TV' and then click on the recordings sub heading. 1
toon 3 Posted April 25, 2019 Posted April 25, 2019 LiveTV is partly working. Seems to depend on client IOS from outside internet works AppleTV local network works windows emby app works on 1 PC local network BUT fails on 2 also on local network??? What can I do to detect and solve the problem?
t.andre 69 Posted May 21, 2019 Author Posted May 21, 2019 Hi, The plugin is updated. - Version : 1.8.7 (2019.05.21) * Fix recordings refresh Cheers
TopSideControl 11 Posted June 2, 2019 Posted June 2, 2019 I'm having problems with the plugin. Playing live & recorded channels does work however it can take a long time for the player to start. Is this just me or have other been having similar issues? 1
QDivision 42 Posted June 2, 2019 Posted June 2, 2019 I'm having problems with the plugin. Playing live & recorded channels does work however it can take a long time for the player to start. Is this just me or have other been having similar issues? I've had the same problem for a while although only with live TV, recorded TV plays within a few seconds but live TV takes up to 30 seconds to play
t.andre 69 Posted June 3, 2019 Author Posted June 3, 2019 I've had the same problem for a while although only with live TV, recorded TV plays within a few seconds but live TV takes up to 30 seconds to play Hi, If you have Hardware acceleration for transcoding please try to disable it to see if it starts faster.
TopSideControl 11 Posted June 11, 2019 Posted June 11, 2019 I'm not using hardware transcoding at all.
TopSideControl 11 Posted August 2, 2019 Posted August 2, 2019 I'm having a problem with the default audio track. Regardless of which client (emby theater, samsung app) the live tv starts with the narrative audio rather than the english (even though english is set as the audio language option and I've unchecked the option to 'play default audio track regardless of language" but it keeps happening. I can switch the audio manually but it reverts back after each channel change.
Luke 42243 Posted August 2, 2019 Posted August 2, 2019 I'm having a problem with the default audio track. Regardless of which client (emby theater, samsung app) the live tv starts with the narrative audio rather than the english (even though english is set as the audio language option and I've unchecked the option to 'play default audio track regardless of language" but it keeps happening. I can switch the audio manually but it reverts back after each channel change. Can we please look at an example? Please attach the ffmpeg log. You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
TopSideControl 11 Posted August 2, 2019 Posted August 2, 2019 Can we please look at an example? Please attach the ffmpeg log. You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks. Just to be clear, I'm not transcoding, does that matter?
Luke 42243 Posted August 3, 2019 Posted August 3, 2019 Just to be clear, I'm not transcoding, does that matter? Please still attach the emby server log. thanks.
Chino123 0 Posted August 3, 2019 Posted August 3, 2019 Hello Everyone, Here you can find a description and change log for the DVBLink and TVMosaic Live TV plugin. Prerequisites TVMosaic version 1.0 DVBLink version 5.0 and above DVBLink version 4 (not tested) Information - Pre and post padding is configured by DVBLink server - Unfortunately it's impossible to get the tuners list from DVBLink API - The plugin only works with IP address - Please change the DVBLink server and port on the plugin configuration page - Timeshift only works with indirect stream. The reason that I provided the option for indirect and direct stream it's because in the past Emby did not release the live stream. If the option of indirect stream works correctly and closes your live TV stream you can use it. - Version : 1.8.7 (2019.05.21) * Fix recordings refresh - Version : 1.8.6 (2019.04.22) * Fix Live TV - Version : 1.8.5 (2019.02.18) * Fix Live TV HD Channel Black Screen with Audio * Fix plugin logo - Version : 1.8.4 (2019.01.22) * Fix plugin recording categories -Version : 1.8.3 (2019.01.14) * Fix plugin image thumb -Version : 1.8.2 (beta) (2019.01.14) - TVMosaic plugin * Fix schedule padding * Fix new schedule active state -Version : 1.7.0 (beta)(2018.09.10) * New TVMosaic plugin * Add the possibility to enable or disable the server * Code fix -Version : 1.6.7 (beta)(2018.06.21) * Update configuration page * Added server status to check if available -Version : 1.6.6 (beta)(2018.06.21) * Add 2 more option to choose favourites group -Version : 1.6.5 (beta)(2018.06.19) * Bug fix * New option to choose 3 kinds of favourites group -Version : 1.6.4 (beta)(2018.06.16) * Bug fix * Add new configuration option to specify Streaming port -Version : 1.6.1 (beta)(2018.05.04) * Update Url Endpoint -Version : 1.6.0 (beta)(2018.04.24) * Update Assembly reference * TVMosaic implementation -Version : 1.5.2 (2017.10.24) * Update Assembly reference -Version : 1.5.1 (2017.10.23) * Update httpclient -Version : 1.5.0 (2017.09.12) * Updated Plugin to .NET Core -Version : 1.3.0 (beta) (2016.10.23) * Update configuration page * Add cache system - Channels : 60mn - Timers: 2mn - Recordings: 2mn - Series: 2mn * Add HD channel information -Version : 1.2.0 (beta) (2016.07.12) *Add DVBLink server channels logo (you have to check the option in configuration page) *Update configuration page -Version : 1.1.6 (2016.03.30) * Fix TunerHostId error -Version : 1.1.5 (2016.03.14) * Fix creation of new timer * Update cache -Version : 1.1.4 (2016.02.10) * Add recordings, channels and scheduled cache (1mn for recordings and scheduled and 60mn for channels) -Version : 1.1.3 (2016.02.10) * Update BufferMs * Update stream successions order -Version : 1.1.1 (2016.02.05) * Add Settings to force Interlaced video * Code fix -Version : 1.1.0 (2016.02.03) * Update ProbeStream * Change version number to semantic version * Fix HD channels close -Version : 1.0.5856.33165 (2016.01.13) - Update code for DVBLink 4 -Version : 1.0.5853.28100 (2016.01.10) - Seek recorded TV is corrected - New Options in configuration page: - Added timeout in minutes until channel playback is stopped by a server - You can now specify your own location for channels logo. If not specified the plugin will use the sub folder named LiveTvLogos in your Emby metadata folder. - You can view opened streams by clients for recordings and LiveTV. When a LiveTV stream is open you have the possibility to close it in the plugin configuration page. Info : the open stream list in the plugin configuration page does not refresh automatically after closing the stream. - Code fix -Version : 1.0.5820.37348 (2015.12.08) - Now you have the opportunity to probe recordin stream before it starts. With this option, audio stream and closed caption will be available in the client side. If you activate this option, the time to display recordings is longer. -Version : 1.0.5800.38018 (2015.11.18) - Now you have the opportunity to probe LiveTv stream before it starts. With this option, audio stream and closed caption will be available in the client side. If you activate this option, the time to display LiveTv is longer. - Cleanup of channels names with special characters to display TV logos. If you have channels with special characters and you don’t want to change them in DVBLink you could rename and replace all invalid characters with an underscore " _" . -Version : 1.0.5778.32831 (2015.10.27) -Implemented Live TV Logo -All you have to do it's to put all your logos with the same name as your tv channels in a subfolder named LiveTvLogos in your emby metadata folder -Version : 1.0.5743.35858 (2015.09.22) -Fix UTF8 xml read -Version : 1.0.5723.31614 (2015.09.02) -Media Stream update -Version : 1.0.5719.32291 (2015.08.29) -Added server side transcoding -Direct http streaming (can fix tuners release) -Server side timeshift -Plugin configuration page display the DVBLink server version (Version 5 and above) -Fix play in Emby Theater Cheers
muppets4 24 Posted August 21, 2019 Posted August 21, 2019 Hi there, I am trying to get it working at a friends place. At my house it is working flawlessly, but overhere I can't seem to work it out. I have the setup working in TV Mosaic. Used baseports 9270 and 9271. Opend both ports manually in the firewall. After installing the plugin and rebooting the server the plugin finds the server. But when I start Live TV I can't see anything. No programs and no guide show. Is there anything obvious I am missing. Does somewhere, besides in the plugin page, something else need to be changed?
pünktchen 1411 Posted August 21, 2019 Posted August 21, 2019 Refresh guide data under Dashboard -> Live TV? 1
muppets4 24 Posted August 21, 2019 Posted August 21, 2019 I do not have filled in any guide in Livetv. The guide tv mosaic is using comes with the dvb-c signal. I was expecting that Emby gets its epg from tv mosaic. Is that not correct?
