QDivision 42 Posted August 16, 2018 Posted August 16, 2018 (edited) I don't need those advance options. I only use series record with the option to record new only (new is set in tvmosaic as programmes with no repeat flag). I don't want to have to touch tvmosaic. I use Emby and Kodi as my front ends. Edited August 16, 2018 by thomasorr
Senna 368 Posted August 16, 2018 Posted August 16, 2018 Then I suggest to make it a feature request topic, instead of posting it here. Because what you want, looks like a general change/addition in Emby's DVR settings.
QDivision 42 Posted August 16, 2018 Posted August 16, 2018 It doesn't need to be a feature request as it would be a plugin change. My first post is a bug with the plugin itself and my second would require an extra option the plugin setting that would send the appropriate API call to tvmosaic/dvblink when requesting a new series schedule. @t.andre can you confirm this?
t.andre 69 Posted August 23, 2018 Author Posted August 23, 2018 Hi, I will check watt I can do and make a new release. for the only new episodes recording, it was already implemented. Cheers
QDivision 42 Posted August 23, 2018 Posted August 23, 2018 Hi, I will check watt I can do and make a new release. for the only new episodes recording, it was already implemented. Cheers How is it already implemented, I don't see any option to set new episodes as the default for new series. When I add a new series recording it defaults to all episodes.
t.andre 69 Posted August 24, 2018 Author Posted August 24, 2018 I have already implemented almost all the features DVBLink and TVMosaic but for now there is no interface or functionality support in emby server. For information I will separate DVBLink and TVMosaic in two plugins and make à publication shortly. Is OK for you guys if there are two plugins ? I use both and it's better than switch the port each time I want to use one of the plugins. Cheers. 1
Schimi 26 Posted August 24, 2018 Posted August 24, 2018 it´s ok so I don´t have to read "DVBlink" text, if I use mosaic :D
Senna 368 Posted August 24, 2018 Posted August 24, 2018 I have already implemented almost all the features DVBLink and TVMosaic but for now there is no interface or functionality support in emby server. That is exactly what I said previously @. If the Emby server interface doesn't support the extra DVBLink/TVMosaic functionality settings, like setting the default DVR recording setting for new Series only , then you can't embed this function in the plugin settings so it seems. So when @@Luke is finished with the important big database changes in Emby Server 3.6.0.3 you can ask him, if there is time to implement this feature in Emby's DVR settings, after 3.6.0.3 is finalized. For information I will separate DVBLink and TVMosaic in two plugins and make à publication shortly. Is OK for you guys if there are two plugins ? Excellent @@t.andre, I'm also still using both DVBLink and TVMosaic in my household
postboy99 4 Posted September 3, 2018 Posted September 3, 2018 (edited) Hi, Im using the DVBLink addon and can watch LiveTV. The problem is with the EPG, it is not loading the TV guide. Table is just empty. Any Idea? Plugin Version: 1.5.3.0 Server Version: 3.5.2.0 2018-09-03 10:48:41.137 Error App: Error refreshing channels for service *** Error Report *** Version: 3.5.2.0 Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -restartpath /var/packages/EmbyServer/scripts/restart Operating system: Unix 3.10.105.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.47 (tarball Sat Apr 21 21:47:26 CST 2018) Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/v3.5.2.0 System.MissingMethodException: string MediaBrowser.Controller.IServerApplicationPaths.get_ItemsByNamePath() at Emby.Server.Implementations.LiveTv.LiveTvManager+<RefreshChannelsInternal>d__66.MoveNext () [0x0004d] in <ea7199aea78e429a84e168a1e154646a>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9f46da0973534d9c8737c50aeebf5ecb>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9f46da0973534d9c8737c50aeebf5ecb>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9f46da0973534d9c8737c50aeebf5ecb>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9f46da0973534d9c8737c50aeebf5ecb>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <9f46da0973534d9c8737c50aeebf5ecb>:0 at Emby.Server.Implementations.LiveTv.LiveTvManager+<RefreshChannelsInternal>d__65.MoveNext () [0x00265] in <ea7199aea78e429a84e168a1e154646a>:0 System.MissingMethodException at Emby.Server.Implementations.LiveTv.LiveTvManager+<RefreshChannelsInternal>d__66.MoveNext () [0x0004d] in <ea7199aea78e429a84e168a1e154646a>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <9f46da0973534d9c8737c50aeebf5ecb>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <9f46da0973534d9c8737c50aeebf5ecb>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <9f46da0973534d9c8737c50aeebf5ecb>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <9f46da0973534d9c8737c50aeebf5ecb>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <9f46da0973534d9c8737c50aeebf5ecb>:0 at Emby.Server.Implementations.LiveTv.LiveTvManager+<RefreshChannelsInternal>d__65.MoveNext () [0x00265] in <ea7199aea78e429a84e168a1e154646a>:0 Edited September 3, 2018 by postboy99
jelbear 0 Posted September 10, 2018 Posted September 10, 2018 I'm having exactly the same issue as postboy99, server and plugin versions the same. No Guide or programme data coming up on the web interface.
t.andre 69 Posted September 10, 2018 Author Posted September 10, 2018 New version of the plugin -Version : 1.7.0 (beta)(2018.09.10) * New TVMosaic plugin * Add the possibility to enable or disable the server * Code fix The change log will be the same for the two plugins. Cheers
t.andre 69 Posted September 10, 2018 Author Posted September 10, 2018 New version of the plugin for Emby 3.6 -Version : 1.8.0 (beta)(2018.09.10) * Switch to DateTimeOffset for compatibility with future version 3.6.0 Cheers
candyman 6 Posted September 10, 2018 Posted September 10, 2018 (edited) New version of the plugin for Emby 3.6 -Version : 1.8.0 (beta)(2018.09.10) * Switch to DateTimeOffset for compatibility with future version 3.6.0 Cheers Hi, t andre Thanks for the update to the plugin. Just to let you know you have a version mismatch You currently have version 1.7.9.0 installed. Select version to install:1.8.0.0 (Beta)1.7.0.0 (Beta) Edited September 10, 2018 by candyman
candyman 6 Posted September 11, 2018 Posted September 11, 2018 (edited) t andre, working fine now, thanks Edited September 11, 2018 by candyman
postboy99 4 Posted September 11, 2018 Posted September 11, 2018 How can I get the beta version installed?
dbarbulescu 0 Posted September 14, 2018 Posted September 14, 2018 (edited) New version of the plugin for Emby 3.6 -Version : 1.8.0 (beta)(2018.09.10) * Switch to DateTimeOffset for compatibility with future version 3.6.0 Cheers Hello, A download link for TV Mosaic Windows Server? https://tv-mosaic.com/en/download/ is not working. Thank you! Edited September 14, 2018 by dbarbulescu
Senna 368 Posted September 14, 2018 Posted September 14, 2018 Hello, A download link for TV Mosaic Windows Server? https://tv-mosaic.com/en/download/ is not working. Try again.... And if you want to report that, you are in the wrong place
angarmgmt 0 Posted September 26, 2018 Posted September 26, 2018 (edited) Just started trialling TV Mosaic and using the plugin with Emby. Is it correct the Emby shows all the channels from TV Mosaic and ignores the channel visibility selections? Update: After some time channel visibility is now correct. Channel numbers are out of sync Edited September 26, 2018 by angarmgmt
Nereos 0 Posted September 29, 2018 Posted September 29, 2018 Hi, can you check the favorites. They are not working on Emby(Web and app). When I use kodi(direct connection to mosaic via plugin), the favorites are ok. Rgds, Soner
Nereos 0 Posted September 30, 2018 Posted September 30, 2018 Checked again and now it works. used user and password. Without it was not working. Now I have the problem, that emby on mobile devices and fire tv I cant open any tv stream only ard. other ones are not able to open.
Luke 42243 Posted September 30, 2018 Posted September 30, 2018 Checked again and now it works. used user and password. Without it was not working. Now I have the problem, that emby on mobile devices and fire tv I cant open any tv stream only ard. other ones are not able to open. Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
WEHA 0 Posted October 28, 2018 Posted October 28, 2018 I'm new to TV mosaic so maybe it's me but when I click record series in Emby and check it in TV mosaic it says inactive in the schedule and there is no red icon in the guide on Emby. The recording does seem to start, is it Emby then that starts the recording? If I click record on an episode in the future, it will not record it but it does show a red icon in Emby, until it actually should record. This is also in the list on TV mosaic itself, inactive. I clicked record series a few weeks ago and only one episode recorded. Since I didn't find any recordings I clicked record series again and now it appears twice in Emby and TV mosaic? emby Version 3.5.3.0 plugin You currently have version 1.7.1.0 installed. TV mosaic Version 1.0.0, Build 16582 Thank you for your assistance!
Luke 42243 Posted October 28, 2018 Posted October 28, 2018 Sounds like you may want to go into tvmosaic and delete one of the duplicate series recordings.
WEHA 0 Posted October 28, 2018 Posted October 28, 2018 Sounds like you may want to go into tvmosaic and delete one of the duplicate series recordings. Well yeah sure, but I'd think this shouldn't happen in the first place? I've checked again and now the "Record series" from this morning now also appears twice in Emby and TV mosaic.
