vaise 340 Posted November 4, 2015 Posted November 4, 2015 Cool - looking on the move to Win 10 as no longer any extenders in use. I am configuring NextPVR and DVBLogic on my NAS to put them head to head, with Emby as the front end.
Spaceboy 2573 Posted November 10, 2015 Posted November 10, 2015 (edited) hi, sorry but this is still playing the audio described track as i posted earlier. i guess you don't have this "benefit" in Switzerland? let me know what info i can provide. the user has english specified as its preferred audio language and the correct track is labelled as english within the stream but i do not have "play default audio regardless of language ticked because not all files i have have english as the default. to me it seems that the plugin is not respecting the users defaults. ta hi @t.andre is there any possibility you could take a look at this please? it seems to be similar to this http://emby.media/community/index.php?/topic/26663-using-nar-narrated-audio-stream-instead-of-english/&do=findComment&comment=261687 thanks Edited November 10, 2015 by Spaceboy
majsorv 1 Posted November 10, 2015 Posted November 10, 2015 Is LiveTV still transcoded (always) by Emby or can you get a direct stream to the client?
t.andre 69 Posted November 10, 2015 Author Posted November 10, 2015 hi @t.andre is there any possibility you could take a look at this please? it seems to be similar to this http://emby.media/community/index.php?/topic/26663-using-nar-narrated-audio-stream-instead-of-english/&do=findComment&comment=261687 thanks Thanks I will see watt can I do.
Spaceboy 2573 Posted November 10, 2015 Posted November 10, 2015 Is LiveTV still transcoded (always) by Emby or can you get a direct stream to the client?You can get a direct stream if your plugin supports it, I'm not sure if dvblink does yet, just having the very same convo on an android to thread. Hoping that @t.andre might be able to look at that soon too!
t.andre 69 Posted November 10, 2015 Author Posted November 10, 2015 You can get a direct stream if your plugin supports it, I'm not sure if dvblink does yet, just having the very same convo on an android to thread. Hoping that @t.andre might be able to look at that soon too! It depends on the client. for exemple if you use Chrome and you have hd channels the stream is direct. but not with Internet explorer.
majsorv 1 Posted November 10, 2015 Posted November 10, 2015 What about applications; Emby Windows app, Emby theater, Kodi? Will those support direct stream?
t.andre 69 Posted November 10, 2015 Author Posted November 10, 2015 Emby theater is ok. Kodi as a native plugin integrated Emby windows I d'ont know. Cheers 1
Spaceboy 2573 Posted November 11, 2015 Posted November 11, 2015 What about applications; Emby Windows app, Emby theater, Kodi? Will those support direct stream? kodi, only kodi. which is very sad
majsorv 1 Posted November 11, 2015 Posted November 11, 2015 Let's hope the new Emby Theater will support it. And also that Edge will include support for h.264 in the future.
Guest Posted November 15, 2015 Posted November 15, 2015 Sorry if this has already been asked, I've had a search and cant see it... I'm new (and very impressed) to Emby and this plugin but have been using MediaCenter extenders and dvblink for a very long time. With the demise of Media Center I'm trying to retire my 6 Xbox extenders and xeon server in favour of this. The only real issue I'm having is, I'd like not to transcode. To replace the Xbox extenders with something which can do MPEG2-TS (DVB-T UK) natively. My reasons on this, lots of different streams would compound the cost of transcoding, more importantly it delays starting a channel on the Emby client (for me at least?). So the questions... 1) If I run with the Media Portal tv plugin I appear to be able to play live tv on Android without transcoding, no ffmpeg process is running on the server. Is this possible with the DVBLink plugin, as ffmpeg always appears to start for me? 2) Other than android can anyone think of a replacement which would allow direct play without transcoding of channels. I like the idea of a Raspberry Pi 2 or a Roku box in every room as I have both those kicking about to test. Apologies if its a stupid question!
t.andre 69 Posted November 16, 2015 Author Posted November 16, 2015 Hi, If your client support direct play, normally it works even if ffmpeg start. It’s a pass-through to check if the stream needs to be transcoded. Luke can correct me if I'm wrong. Cheers.
Guest Posted November 17, 2015 Posted November 17, 2015 Hi, If your client support direct play, normally it works even if ffmpeg start. It’s a pass-through to check if the stream needs to be transcoded. Luke can correct me if I'm wrong. Cheers. Thanks, I'll double check but ffmpeg appears to be consuming some CPU, say 8%... which is a little lower than normal maybe but still "doing something". Thanks again though, I wasn't aware of that.
Spaceboy 2573 Posted November 17, 2015 Posted November 17, 2015 Hi @t.andre emby transcodes dvblink to chrome browser for me. I've tried most clients and they all transcode in my experience. What info can I provide you to help look at this further? Cheers
pünktchen 1411 Posted November 17, 2015 Posted November 17, 2015 (edited) @@t.andre Emby doesn't ffprobe a live tv stream! Instead Emby relies on mediainfo about videocodecs, audiocodecs, bitrate, container, profile and level for x264. Depending on this and the capabilities of the requesting client, Emby decides if live tv needs to be transcoded. So the question is: do you deliver any mediainfo besides the streaming url? Edited November 17, 2015 by pünktchen
t.andre 69 Posted November 17, 2015 Author Posted November 17, 2015 I thanks for your answer. Unfortunately DvbLink does not provide information in what is steamed. In my plugin we can use two options for the stream request. The first one is for transcoded stream directly from DvbLink , with this option I can transmit all the properties given by Emby to the server. And the second option is raw streaming from URL without transcoding, I use the same parameters as HdHomerun for native mpeg2video. Here the code I use for raw streaming. MediaStreams = new List<MediaStream> { new MediaStream { Type = MediaStreamType.Video, // Set the index to -1 because we don't know the exact index of the video stream within the container Index = -1, IsInterlaced = true, Codec = "mpeg2video" Width = null, Height = null, BitRate = null }, new MediaStream { Type = MediaStreamType.Audio, // Set the index to -1 because we don't know the exact index of the audio stream within the container Index = -1, Codec = "aac", BitRate = 128000 } }, RequiresOpening = true, RequiresClosing = true, BufferMs = 1000, Container = "ts", Id = profile, SupportsDirectPlay = true, SupportsDirectStream = true, SupportsTranscoding = true Cheers.
pünktchen 1411 Posted November 17, 2015 Posted November 17, 2015 I would also set some overall birate (same level as container), maybe 5000000. And i remember i had some problems with an index of "-1" for video and audio. If you hardcode those parameters i would set 0 for video and 1 for audio. I can't imagine a case were video and audio would be delivered in an reverse order.
t.andre 69 Posted November 17, 2015 Author Posted November 17, 2015 I can probe the info from IMediaEncoder buts it will take longer to display live stream
pünktchen 1411 Posted November 17, 2015 Posted November 17, 2015 We do something similiar for MediaPortal One cannot have it all - either or... Just make it an option for your users!
t.andre 69 Posted November 17, 2015 Author Posted November 17, 2015 Have tried already and it works. I will publish an update soon 1
Guest Posted November 18, 2015 Posted November 18, 2015 Thanks all. Sorry I should have said as well, if I can do anything to help debugging please say.
t.andre 69 Posted November 18, 2015 Author Posted November 18, 2015 Hi, I have published a new version. Please see the first post for more information. Cheers
Spaceboy 2573 Posted November 18, 2015 Posted November 18, 2015 (edited) Hmm somethings not right, I need to investigate more fully but streams didn't seem to be being closed and I had 9 going at one point. Also ffmpeg was hammering the cpu for playback in the web client so not sure it's direct streaming. Will investigate further when I have some time Yeah sorry it's still transcoding in the webclient. Would transcode logs be helpful? Edited November 18, 2015 by Spaceboy
pünktchen 1411 Posted November 19, 2015 Posted November 19, 2015 Hmm somethings not right, I need to investigate more fully but streams didn't seem to be being closed and I had 9 going at one point. Also ffmpeg was hammering the cpu for playback in the web client so not sure it's direct streaming. Will investigate further when I have some time Yeah sorry it's still transcoding in the webclient. Would transcode logs be helpful? For the webclient the stream will allways be transcoded because no browser can handle a ts stream.
