Casper 29 Posted November 1, 2013 Posted November 1, 2013 (edited) quick how to use 1. download the Photoshop Temp folder and save it to your C:\drive 2. your folder structure should look like this 3. Go to the PS Action folder and install the Action 4. Copy the Photoshop Droplet to your Desktop 5. Drag your image onto the Droplet 6. Run the Action 7. Go to the Output folder, to get your newly created fanart... Download here : Dropbox Video added on how to use : how to discs.wmv Download here : Dropbox Edited July 26, 2015 by Casper 9
Casper 29 Posted November 6, 2013 Posted November 6, 2013 (edited) Download here : Dropbox Edited November 5, 2013 by Casper
Casper 29 Posted November 6, 2013 Posted November 6, 2013 (edited) Download here : Dropbox Important: Rename your files, Marquee = 1.png | Snap = 2.png | Flyer = 3.png and copy them to the Image Processing folder before you run the Action... Edited November 5, 2013 by Casper 3
Casper 29 Posted November 6, 2013 Posted November 6, 2013 The PSD file is now updated for games.... the following layers were added..... Download here : Dropbox 2
Casper 29 Posted November 6, 2013 Posted November 6, 2013 (edited) Download here : Dropbox Part 1 (Select Your Platform) : there is a Logo for all GameBrowser III Platforms located in the Image Processing folder Part 2 (Select Your Disc) : download, make your own or use one of the ready made discs... Part 3 (Save it) Edited November 5, 2013 by Casper
Casper 29 Posted November 9, 2013 Posted November 9, 2013 (edited) Download here : Dropbox Part 1 (Insert Image) Drag Your image onto the Droplet... Edit the text layer, typing the name of the Artist or make the text layer NOT visible and add your Artist 's Logo manually Part 2 (Create Logo) An extra image is created from the Text Layer (resize it to fit the canvas) Part 3 (Save !) You now have a nice artist image as well as a logo in the output folder. This is how it looks in ROC / Crystal Themes (View: Thumb strip) Edited July 26, 2015 by Casper 2
Casper 29 Posted November 9, 2013 Posted November 9, 2013 All Actions have been updated... Some minor errors fixed
Blueeyiz702 223 Posted July 23, 2015 Posted July 23, 2015 Casper ,is there a certain edition of photoshop that you use to do this with?
Blueeyiz702 223 Posted July 25, 2015 Posted July 25, 2015 where is droplet located im new at this a learning still,thanks
Casper 29 Posted July 25, 2015 Posted July 25, 2015 (edited) Download the Photoshop temp Folder from Dropbox Edited July 25, 2015 by Casper
Casper 29 Posted July 25, 2015 Posted July 25, 2015 (edited) Made a video for you.... quick video.wmv Edited July 25, 2015 by Casper
Teddy 100 Posted July 25, 2015 Posted July 25, 2015 (edited) Casper, could be possible for Bluray around movie cover? There are a lot of Bluray movies with not cover and I'm using the DVD cover. Thanks for your great work. Edited July 26, 2015 by Teddy
Blueeyiz702 223 Posted July 25, 2015 Posted July 25, 2015 (edited) Im using Adobe Photoshop cc 2015,will this work i do i need to change programs? im also getting,cant communicate with droplet error? Edited July 26, 2015 by blueeyiz7021
Casper 29 Posted July 26, 2015 Posted July 26, 2015 (edited) Download here : DropBox Edited July 26, 2015 by Casper
Casper 29 Posted July 26, 2015 Posted July 26, 2015 Im using Adobe Photoshop cc 2015,will this work i do i need to change programs? im also getting,cant communicate with droplet error? It working on CS6 and CC 2015... You can start here for error https://forums.adobe.com/thread/676607?tstart=0
Teddy 100 Posted July 26, 2015 Posted July 26, 2015 Casper, I thing did every step but the folder results has white borders. I did something wrong?
Teddy 100 Posted July 26, 2015 Posted July 26, 2015 (edited) Casper, I forget to say I used 600x800 or 2000x3000 image but always I get the white borders. Edited July 26, 2015 by Teddy
Casper 29 Posted July 26, 2015 Posted July 26, 2015 (edited) What browser are you using ? / With what app are you viewing the image ? It can be a lot of things... try to give more info, so I can better help you Internet Explorer is Not that good with PNG files And don't use MS Paint as it does NOT support transparency... http://www.howtogeek.com/howto/7955/how-to-fix-no-aero-transparency-in-windows-7/ Edited July 26, 2015 by Casper
Teddy 100 Posted July 26, 2015 Posted July 26, 2015 (edited) Thanks to support Casper. I'm using ACDsee as viewer, Photoshop CS6 Portable, browser Firefox. I attach a hardcopy as is showed in Emby for Mediacenter. And attach too the picture, if you want try it. (The picture is 600x800 but if resize to 2000x3000 the results are the same. Seems the PSD transparency is not working for me. Edited July 26, 2015 by Teddy
Casper 29 Posted July 27, 2015 Posted July 27, 2015 (edited) Try this: and Your image is fine on my PC..... I'm using ACDsee as viewer, Photoshop CS6 Portable, browser Firefox. These can all do transparency.... and should work fine So, the problem is NOT with the image, but the way the image is displayed on YOUR PC... Edited July 27, 2015 by Casper
Teddy 100 Posted July 27, 2015 Posted July 27, 2015 (edited) Thanks again to support, Casper. It is an issue that is really driving me crazy. I have reviewed the transparency in Windows 7 on my 2 computers and apparently have no problems. I did a hardcopy of a folder with transparency (The Godfather Collection) that works well in Emby for Mediacenter, but the other does not work well with transparency.I have no knowledge of Photoshop but it could not be any different attribute transparency? Edited July 27, 2015 by Teddy
Teddy 100 Posted July 27, 2015 Posted July 27, 2015 Casper, finally I got it. The solution for my was to install the CS5 version and your PSD are working excellent. Thanks again for your time.
