topender 1 Posted January 4, 2015 Posted January 4, 2015 Hello guys This issue has me stumped and hoping i can get some help here I recently upgraded to a synology nas. But for some reason everything i try to play on my HTPC as media from it just comes up with a black screen and stuttering audio My setup is Win 7 WMC Mediabrowser classic only changes to default installs is vobsub. no additional codecs or anything The same media works fine from my previous Win home server setup And also works fine with VLC on the HTPC from the synology But for some reason cannot play via mediabrowser. Any ideas or pointers for troubleshooting is appreciated Thanks T
Luke 42241 Posted January 4, 2015 Posted January 4, 2015 Please see http://mediabrowser.tv/community/index.php?/topic/790-how-to-report-a-problem/
ebr 16334 Posted January 4, 2015 Posted January 4, 2015 It is probably a permissions or access problem so MBC is trying to stream instead of directly playing the media.
topender 1 Posted January 4, 2015 Author Posted January 4, 2015 Please see http://mediabrowser.tv/community/index.php?/topic/790-how-to-report-a-problem/ Im not sure its a MB problem per se
topender 1 Posted January 4, 2015 Author Posted January 4, 2015 It is probably a permissions or access problem so MBC is trying to stream instead of directly playing the media. This is what i was thinking. That MB may have been requesting the synology to do the transcoding and heavy lifting. Not sure where i can change that I have the media in a mapped drive from the synology and have given the HTPC read write access to the drive.
ebr 16334 Posted January 5, 2015 Posted January 5, 2015 Don't use mapped drives. Use UNC paths. Much more reliable and accessible from any machine.
topender 1 Posted January 5, 2015 Author Posted January 5, 2015 Will change that and see if it makes any difference to the playback
AdrianW 1058 Posted January 5, 2015 Posted January 5, 2015 ...That MB may have been requesting the synology to do the transcoding and heavy lifting. Have you installed the server on the Synology - or on a Windows PC? The only location transcoding takes place is on the machine where MB server is installed.
topender 1 Posted January 5, 2015 Author Posted January 5, 2015 The server is installed on the HTPC. Its had no issues with playing the same media off my WHS but i want to decommission it and move all the media to the synology
AdrianW 1058 Posted January 5, 2015 Posted January 5, 2015 The server is installed on the HTPC. Its had no issues with playing the same media off my WHS but i want to decommission it and move all the media to the synology It sounds like permissions and/or access issues - like ebr mentioned above, you need to make sure you added your media locations using UNC paths (e.g. \\servername\sharename\foldername) when you defined your Media Library. The location of the media (WHS or Synology) should make no difference at all to how it plays back on a client. 1
topender 1 Posted January 7, 2015 Author Posted January 7, 2015 Still stumped Have changed to unc paths with no success Two symptoms showing. Some media plays with just a black screen. Can here sound and skip forwards/backwards Some other media when you hit play just gives black screen and 0.00 on timebar Media server picks up the series no problems and populates metadata Have tried deleting and reading. Dunno what else to try
topender 1 Posted January 7, 2015 Author Posted January 7, 2015 (edited) Just tried playing same media from Android app and the media which just shows no picture plays fine. The other media which shows no timebar just comes up with spinning loading iconr Edited January 7, 2015 by topender
ebr 16334 Posted January 7, 2015 Posted January 7, 2015 I still need to see an MBC log to have any clue what is going on. Thx.
