wolfbuddy 16 Posted January 3, 2015 Posted January 3, 2015 Please, please can you add the ability to skip through the library by first letter like in MBC and WMC? It's so much quicker and less clunky to find things this way with a remote, as opposed to using the search tool. 2
foghat 65 Posted January 4, 2015 Posted January 4, 2015 Yes, this or something similar is desperately needed. It has been asked for before. There needs to be a better way to get to movies. The search is not very good the way it is set up and trying to use a touch screen remote with it is an absolute exercise in futility. It is at the point that if I am watching an already viewed movie, I will mark it as unwatched via the web interface so that it shows up in my unwatched section (which only has a few movies at a time)
Deathsquirrel 745 Posted January 4, 2015 Posted January 4, 2015 It s coming in the new MBT architecture release though no ETA on that that i know of.
wolfbuddy 16 Posted January 4, 2015 Author Posted January 4, 2015 I seem to be finding a lot of things that are being worked on. For the time being, I'll use cast from my tablet or phone. I'm leaning towards using MBT over MBC because of the addition of the MadVR renderer which seems to make my mid-range projector appear a little more expensive than it really is.
