panda 1 Posted January 1, 2015 Posted January 1, 2015 Hello all, This is my first venture into HTPC and into this community. Hello! I want to report on some issues I am having with playlists and the web interface on the same computer as the server - I haven't uploaded any logs in case I am being a noob and have missed something obvious: 1) A playlist category is not appearing anywhere - not on the home screen, and not in the menus. 2) I can add music tracks or an entire music album to a new playlist. However, I cannot see existing playlists in the slide out menu - I don't think playlists are being saved, and this might be affecting (1) above? 3) The only time I can see and play a playlist is when I add tracks to a new one. However, once I navigate away, I cannot get back to it - again, see (1). I am using Windows 8.1 x86, Media Browser v3.0.5464.40000, and have tested with IE 11 and Palemoon 24.7.2. I hope this information helps.
Luke 42184 Posted January 1, 2015 Posted January 1, 2015 Hi, unfortunately this is a problem in the current release. Once you create it, you can't get to it. It's resolved for the next release which will be out any day now. Thanks.
panda 1 Posted January 2, 2015 Author Posted January 2, 2015 Oh wow, thanks for the quick reply, and the quick patch! Managing playlists was the only thing I was missing from Foobar. Thanks!
