sprtfan 3 Posted October 30, 2013 Posted October 30, 2013 Thanks, I don't remember seeing a warning mentioning that but I'll restart the install and see if I get one. I'll also update explorer.
sprtfan 3 Posted October 30, 2013 Author Posted October 30, 2013 I checked and I was running IE10 and also have compatibility mode turned off. I turned compatibility mode back on just to check and I did get a pop up message warning me. I seem to be still having a problem even though I'm using IE10 and have compatibility mode turned off. Any other ideas? Thanks
Solution Luke 42288 Posted October 30, 2013 Solution Posted October 30, 2013 There was another user who had issues with IE in WHS due to security settings. I don't remember what they were. Try poking around with those and please report if you're able to solve it. Otherwise install chrome or firefox and you'll be good to go. 1
sprtfan 3 Posted October 30, 2013 Author Posted October 30, 2013 To be able to download the server, I was asked to added mb3admin.com to my list of trusted sites and did. The security is set pretty high in explorer on my WHS install. Could that be part of the problem?
sprtfan 3 Posted October 30, 2013 Author Posted October 30, 2013 sorry, was typing my last reply while you were posting yours. I'll give that a try and go with a different browser if problem remains. Thanks
sprtfan 3 Posted October 30, 2013 Author Posted October 30, 2013 I installed Firefox and everything is working now. Thanks again for all of the help
sprtfan 3 Posted October 31, 2013 Author Posted October 31, 2013 (edited) I'm installing media browser server on my WHS 2011 server. I downloaded and ran it and I get to the Welcome to Media Browser Server! and click next to start the setup process but nothing happens. The Welcome to Media Browser Server! message opens in explorer and the address is "://localhost:8096/mediabrowser/dashboard/wizardstart.html" Thanks for any help Edited October 30, 2013 by sprtfan
Luke 42288 Posted October 31, 2013 Posted October 31, 2013 Make sure it's IE10+ and compatibility mode is off. There's supposed to be a warning that tells you that. Did you not get one? Let me know and if that's the case I'll look into it.
Vlaves 2 Posted July 4, 2014 Posted July 4, 2014 I'm facing the same problem, but I'm already using Firefox and the Wizard page is not displayed. Where should I look, are there any logs I could look at regarding such a Issue? Probably not, since I think this has somthing to do with the System config. What can I do or should I try? Thanks for your support Regards Vlaves
Vlaves 2 Posted July 7, 2014 Posted July 7, 2014 Hello together, is there no one who could help me out where to look for this error? I just don't know where to start, as it seems to work for others when using Firefox. Thanks again for any hint. Regards Vlaves
Luke 42288 Posted July 7, 2014 Posted July 7, 2014 Hello together, is there no one who could help me out where to look for this error? I just don't know where to start, as it seems to work for others when using Firefox. Thanks again for any hint. Regards Vlaves Can you supply more information? What exactly are you seeing?
Vlaves 2 Posted July 7, 2014 Posted July 7, 2014 (edited) Can you supply more information? What exactly are you seeing? I would describe it like this. The Server is installing without an issue. And after Installation, the Server starts (can see it in the systray) and then Firefox is starting, which tries to open the page "http://localhost:8096/mediabrowser/dashboard/wizardstart.html" but it is saying after a while that the page could not be displayed. I also accepted/confirmed the Firewall exception for all networks. The Page just could not be displaed Hope I could explain it, so you could help me out here. Thanks again for your support Regards Vlaves Edited July 7, 2014 by Vlaves
Luke 42288 Posted July 7, 2014 Posted July 7, 2014 I would describe it like this. The Server is installing without an issue. And after Installation, the Server starts (can see it in the systray) and then Firefox is starting, which tries to open the page "http://localhost:8096/mediabrowser/dashboard/wizardstart.html" but it is saying after a while that the page could not be displayed. I also accepted/confirmed the Firewall exception for all networks. The Page just could not be displaed Hope I could explain it, so you could help me out here. Thanks again for your support Regards Vlaves Please find the server log and supply that: http://mediabrowser.tv/community/index.php?/topic/790-how-to-report-a-problem/ Thanks.
