mshollack 0 Posted December 30, 2014 Posted December 30, 2014 Whenever I stream certain content to my dish hopper or Joey clients the director commentary will play. If I play it from Kodi or on the MB server it plays fine. Any ideas or hints? I have ripped all my movies to mkv using make mkv.
Luke 42184 Posted December 30, 2014 Posted December 30, 2014 Need to see a specific example, along with the media info displayed in the web interface.
Luke 42184 Posted December 30, 2014 Posted December 30, 2014 and also check what user you've assigned to dlna in the server dashboard under Dlna. it will take into account the language preferences of that user.
mshollack 0 Posted December 31, 2014 Author Posted December 31, 2014 Thank you, I did check this as you recommended. I did have a user selected and English set as the preference. I noticed that this mkv had multiple audio tracks. For whatever reason the hopper clients kept bypassing track ID 1 which was the 5.1 track and jumping to track ID 3 which was the stereo track. I was able to fix it by remixing the mkv and removing this track. Now it plays correctly on the dnla clients. Hopefully this might help with a possible bug.
Luke 42184 Posted December 31, 2014 Posted December 31, 2014 well it depends. if it's direct streaming then the hopper is playing the file as-is. we have no ability to control what track it chooses. if the server is transcoding then we can control that and i don't believe there's any bug there.
