Mark Anderson 2 Posted October 30, 2013 Posted October 30, 2013 Hi Guys recently upgraded to MB2 and MBClassic. been a while since I used MB. I have a movies by genre folder and inside that a folder for each movie. (I have no themes loaded) Genre Folder when I hover over a genre folder, I don't get any backdrops displayed (I'd like some of the backdrops from the movies in the genre folder). Instead, i get a list of movies displayed. When I go into the genre folder, all my movie icons have got 1080P/720P icons on top. Can't for the life of me figure out how to get rid of those. Folder Settings If I go into action folder for example and set it to thumb strip/use coverflow settings, it changes the folder, but all others are at old settings. Is there a way to change all genre folders to be the same. I have about 30, so it would take ages to change them all 1 by 1 every time I edit something My Genre icons are all missing. Haven't a clue where to install these in MB3 and MBC Can anyone point me in right direction? Thanks Mark
Mark Anderson 2 Posted October 31, 2013 Author Posted October 31, 2013 Hi ebr I did spent quite a bit of time perusing knowledge base, etc. I finally ended trying several theme and settled on Destiny theme, which does most of what I want, except showing a random backdrop in when I hover over a genre folder in movies by genre
