Is It Possible To Exclude a Library?
Go to solution Solved by BATTLE DONKEY,
Is it possible to exclude a library from MBC?
I have setup a music library on Media Browser Server, but due to the size of it it's simply not usable in Media Browser Classic - long delays in navigating the menus, and occasional crashes. I'd like to keep the library in MB Server if possible.
Any thoughts?
  • Solution
BATTLE DONKEY
You could create a specific user for MBC that excludes music. Assuming you're only using one user profile you can have MBC log into this new MBC specific profile automatically, and use your original profile for other apps that better handle the large music library
  • Like 1
Thanks for the suggestion - I will give this a try.
