Mark Anderson 2 Posted October 29, 2013 Posted October 29, 2013 Hi Guys Recently upgrade to MB 3 with MBC. One of my WMC machines is running the server and client and the other is just MBC. With MB3, do I still need an IBN folder on each machine and have to refresh each one? If I still need one per machine, what's the easiest way to sync them All my movies are on a NAS and I use UNC paths for everything. Do I just need to have the server PC update when I copy a new movie to my NAS? If so, can I do this in the MBC UI, or do I need to go somewhere else to force and update? Can I do it remotely? For example can I get the server to update from something on the machine running just MBC? TIA Mark
ebr 16332 Posted October 29, 2013 Posted October 29, 2013 The server handles all library functions. The IBN lives in one place and is pointed to by the server.
Mark Anderson 2 Posted October 30, 2013 Author Posted October 30, 2013 The server handles all library functions. The IBN lives in one place and is pointed to by the server. Thanks for reply. So where do I put my genre icons, so that all clients get them?
ebr 16332 Posted October 30, 2013 Posted October 30, 2013 Imagesbyname directory on the server or wherever you point it in the configuration.
