Shyatic 5 Posted October 29, 2013 Posted October 29, 2013 I have an issue with playback where if I enable the subtitles, the movie will either restart, or just stop playing entirely... it's really annoying. Thanks for any advice!
Luke 42287 Posted October 29, 2013 Posted October 29, 2013 Move this to the support section for the client you're trying to play with. Based on your provided information we have no idea what app you're using.
Shyatic 5 Posted October 29, 2013 Author Posted October 29, 2013 Move this to the support section for the client you're trying to play with. Based on your provided information we have no idea what app you're using. Will do -- it's the web browser, MBC can't play back external .SRTs from my knowledge.
yardameus 221 Posted October 30, 2013 Posted October 30, 2013 Yes, it can play back external .srt files. That's almost exclusively what I use. It more depends on the codec settings, since it's essentially WMP playing it.
Shyatic 5 Posted October 30, 2013 Author Posted October 30, 2013 Yes, it can play back external .srt files. That's almost exclusively what I use. It more depends on the codec settings, since it's essentially WMP playing it. Not on an extender
Marc_G 95 Posted November 16, 2013 Posted November 16, 2013 How do I use subtitles in mbc? See details in your thread over here: http://mediabrowser.tv/community/index.php?/topic/2064-sub-titles-with-lav/
