smarty39 0 Posted October 29, 2013 Posted October 29, 2013 Just curious if I need to have my NAS (library) mapped as a network drive on my MBC machine? To me, the fact that MBS is 'hosting' everything and streaming from within makes me think that the mapped drive shouldn't be necessary...does that make sense? As I have it right now, I cannot play my media without the drive mapped...is this just the way it is? TIA
smarty39 0 Posted October 29, 2013 Author Posted October 29, 2013 Correct, as of right now I cannot play my media without my NAS drive (where my media is stored) mapped. Not a huge deal, was more just curious. It doesn't really make sense to me though as having the server aspect of MB should eliminate the need for drive mapping, or am I still missing something?
CBers 7554 Posted October 29, 2013 Posted October 29, 2013 @@smarty39 - can you access your NAS via UNC? If so, then this is how you need to add your data to MB3.
ebr 16332 Posted October 29, 2013 Posted October 29, 2013 You need to define your library on the server using UNC paths as suggested on that screen. Mbc is not designed to stream.
smarty39 0 Posted October 29, 2013 Author Posted October 29, 2013 Yes, I can access via UNC...I'll try that instead tonight @@Luke - not sure how much more detail I can give? If I have the drive mapped (in my case V:\NAS\Video) on the local machine (machine running MBC) everything works fine. If I don't have it mapped then I can't play any media, but all the metadata, etc. shows up properly.
smarty39 0 Posted October 29, 2013 Author Posted October 29, 2013 Thanks for the quick replies...I will switch to UNC pathing tonight when I get home. Cheers!
smarty39 0 Posted October 29, 2013 Author Posted October 29, 2013 No it is not. MB3 Server is on it's own PC. My library (NAS) is on it's own, and every instance of MBC is on its own. I just logged in using the web browser (great addition btw) and changed all my folder paths to UNC. I will test when I get home but I'm sure that is all I was missing. Thanks again for the quick help!
Luke 42237 Posted October 30, 2013 Posted October 30, 2013 Describe As I have it right now, I cannot play my media without the drive mapped
Luke 42237 Posted October 30, 2013 Posted October 30, 2013 But you still haven't gone into any detail beyond "I can't do it". So it's hard to help if that's all the information you can provide.
