mdean1120 0 Posted December 27, 2014 Posted December 27, 2014 I recently (today) upgraded from Media Browser 2 to 3. I really like the new player interface, but I can't skip forward 30 sec, or jump to the middle of a movie like I used to be able to. Most of my movies are mkv (h264) make with handbrake. I thought it didn't work at all until I tried playing an AVI movie I ripped. The AVI worked just as the usage guide describes. I saw a post the mentioned maybe the 5.1 is the cause? I tried: MKV w/2ch AC-3 audio Fails MKV w/2ch mp3 audio Fails MKV w/6ch AC-3 audio Fails Is this a known issue? Is there a fix in progress? Other notes: Resume does not even show up if you stop playback Clicking on a chapter always restarts the movie. This happens on 2 different client PCs (windows 7) Thanks, Michael
steelman1991 19 Posted December 27, 2014 Posted December 27, 2014 Have a look at this thread - http://mediabrowser.tv/community/index.php?/topic/7680-new-internal-player-interface-usage-guide/ Some of the functionality has changed, but is explained there. Not sure why 'resume' isn't showing up, other than you might not have played past the point where resume becomes functional - I think this can be user set from the Server Dashboard (yip - under Playback).
mdean1120 0 Posted December 27, 2014 Author Posted December 27, 2014 I did find and read over that and none of those functions work for the MKV (h264) files. They do work for the one AVI (divx) file I tried.
ebr 16334 Posted December 27, 2014 Posted December 27, 2014 Be sure your items are actually direct playing and not streaming from the server. Please post an MBC log when you attempt these operations.
mdean1120 0 Posted December 27, 2014 Author Posted December 27, 2014 This seems to indicate it is transcoding? I understand why that would prevent skipping. Why is it transcoding? I increased the local network max bitrate as high as it would go (40) and have the warn if streaming checked. I did not see a warning, but i might just be missing it. 2014-12-27 12:32:50.8661 Info - App: SessionInfoWebSocketListener stop transmitting over websocket to 192.168.15.100:555412014-12-27 12:32:50.8661 Info - App: ScheduledTasksWebSocketListener stop transmitting over websocket to 192.168.15.100:555412014-12-27 12:33:43.7339 Info - App: /media/81736aca-ec4b-4861-94db-4debb6890d26/mediabrowser/ffmpeg/20140716/ffmpeg -fflags +genpts -i file:"/mnt/samba/Movies/Frozen/Frozen.mkv" -map 0:0 -map 0:1 -map -0:s -vcodec msmpeg4 -force_key_frames expr:gte(t,n_forced*5) -vf "scale=min(iw\,720):trunc(ow/dar/2)*2" -mbd 2 -b:v 933788 -vsync vfr -map_metadata -1 -threads 0 -acodec wmav2 -ac 2 -ab 128000 -af "aresample=async=1,volume=2" -y "/media/81736aca-ec4b-4861-94db-4debb6890d26/mediabrowser/transcoding-temp/4b338fe96080c1d07481b25010d66bbf.asf"
mdean1120 0 Posted December 27, 2014 Author Posted December 27, 2014 Ok, I think i understand. I need to use Path Substitution to get this to work like i want.
ebr 16334 Posted December 27, 2014 Posted December 27, 2014 Ok, I think i understand. I need to use Path Substitution to get this to work like i want. Yep.
tornadotj 6 Posted December 30, 2014 Posted December 30, 2014 I am directly playing, and I have these same issues. I connect to (for example) \\192.168.1.1\movies for content. I also have a substitution set up, just in case. I think we may have two threads for the same issue going?
