ginjaninja 605 Posted December 24, 2014 Posted December 24, 2014 with the same amount of internet bandwidth, some of my trailers* are closer to 720p and some 320p..is there a way to stipulate minimum resolution for a trailer.the lowest resolutions are too low on a projector screen. ty *the kind of trailers that play from online sources.
mariors44 18 Posted December 24, 2014 Posted December 24, 2014 you probably have look for them on the web yourself. That's is what I do. I think the way trailer plugin works is that it gets the first available trailer.
Happy2Play 9798 Posted December 24, 2014 Posted December 24, 2014 Don't know how well it works but the default setting in trailer channel is "Best available", Have you tried changing that? 2
ginjaninja 605 Posted December 28, 2014 Author Posted December 28, 2014 Don't know how well it works but the default setting in trailer channel is "Best available", Have you tried changing that? ty for drawing my attention to this...ir was on 720p but ive increased trhe disks space and will try again..
