gismo33 5 Posted December 23, 2014 Posted December 23, 2014 (edited) Hello, I used MediaBrowser-Server on Ubuntu. I installed it maybe 1-2 monath ago. Now i cant access to MediaBrowser on Firefox with "http://localhost:8096/mediabrowser". Then i tried with following steps to uninstall Mediabrowser: 1) apt-get autoremove mediabrowser 2) manually remove the ppa:apps-z/mediabrowser - repository 3) In Nautilus: searched & removed all "mediabrowser" related files After that i restarted and execute that steps: - sudo add-apt-repository ppa:apps-z/mediabrowser- sudo apt-get update- sudo apt-get install mediabrowser- service mediabrowser start- visit http://localhost:8096/mediabrowser But still i cant access to mediabrowser. On Firefox just appears "unable to connect". Do you can help me? Edited December 23, 2014 by gismo33
wolfbuddy 16 Posted December 23, 2014 Posted December 23, 2014 Try replacing 'localhost' with the actual IP address.
gismo33 5 Posted December 24, 2014 Author Posted December 24, 2014 Thanks, but i tried this already yesterday. It doesn't matter if i use localhost or the IP. I also tried to open the Port 8096 in my firewall, but it doesn't help. Any other ideas? I don't want to reinstall Ubuntu on my VM
gismo33 5 Posted December 24, 2014 Author Posted December 24, 2014 I included the two log-files from /var/lib/mediabrowser/logs Maybe it helps. server-63555026869.txt unhandled_76bbe0c2-074a-425c-becd-ddc7952a8ee4.txt
thefirstofthe300 292 Posted December 25, 2014 Posted December 25, 2014 I included the two log-files from /var/lib/mediabrowser/logs Maybe it helps. You seem to be missing sqlite3. Are both sqlite and sqlite-dev installed? @ I thought that this issue was fixed.
hurricanehrndz 149 Posted January 5, 2015 Posted January 5, 2015 (edited) I added it as a dependency, so the apt-get should tell the user that its missing. And then it's up to the user to install the missing dependencies listed by apt-get. Edited January 5, 2015 by hurricanehernandez
