babgvant 143 Posted December 23, 2014 Posted December 23, 2014 babgvant - when you see this, he started out asking for lav settings in the beginning of the thread, but the root issue is actually the long delay when playing as well some failures in the log. It's possible that LAV isn't downloading properly (which would cause a long delay).
Luke 42239 Posted December 23, 2014 Posted December 23, 2014 Please try deleting the COMObjects folder in the MBT config folder. MBT should download LAV (and all the filters it needs) automatically. There maybe an issue with the updating process (it's hard to test all the permutations). maybe if it's failing to overwrite we could name the folder with the com objects version, e.g. comObjects1.3.4....then after the new ones are downloaded try to cleanup the old ones. if it fails, worst case scenario is extra files left behind, but at least the new ones will still be there and available just an idea, this might not be the actual problem
Luke 42239 Posted December 23, 2014 Posted December 23, 2014 It's possible that LAV isn't downloading properly (which would cause a long delay). right, it must be failing for him for some reason and then retrying over and over
babgvant 143 Posted December 23, 2014 Posted December 23, 2014 What Luke is saying, in a not so diplomatic way, is that most of the LAV configuration settings are found in the MBT settings section. When you change the settings in MBT, what you are actually doing is changing the underlying LAV settings. I'm not a fan of hiding LAV configuration from the user, it confuses most who are familiar with LAV, it is not all inclusive & sometimes the changes don't "stick." In my opinion, LAV should remain a stand alone installation. I understand this perspective, but in my experience it is unsupportable. What version is the user running? How is it setup? What other cruft is joining the graph? If you have a compelling argument for why/how it is better for the majority of users to have to maintain the DS ecosystem please share it.
Luke 42239 Posted December 23, 2014 Posted December 23, 2014 Yea, babgvant is right. We made a team decision about this. There are always going to be power users who prefer to use their own LAV and we understand that, but the vast majority of people just want to be able to watch their movies and aren't really worried about it. Just look at what Ebr has to deal with with MBC, since windows media center relies on system installed codecs - "I installed xyz codec pack and now MBC is broken.". We don't want to have to deal with that anymore.
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 ive tried deleting the COMObjects folder with no change
babgvant 143 Posted December 23, 2014 Posted December 23, 2014 maybe if it's failing to overwrite we could name the folder with the com objects version, e.g. comObjects1.3.4....then after the new ones are downloaded try to cleanup the old ones. if it fails, worst case scenario is extra files left behind, but at least the new ones will still be there and available just an idea, this might not be the actual problem There are scenarios where MBT could get into a race while updating the components, but restarting should resolve that. I'll have to think on it a bit. If deleting the COMObjects folder fixes the problem, then I'll have something to go on. If it doesn't, the files DL properly and the issue persists it could be a system specific issue.
babgvant 143 Posted December 23, 2014 Posted December 23, 2014 ive tried deleting the COMObjects folder with no change Does it recreate itself with subfolders for each filter containing dlls/ax/etc when MBT starts?
Luke 42239 Posted December 23, 2014 Posted December 23, 2014 ive tried deleting the COMObjects folder with no change I think one of the main reasons this thread has taken so long to get you help is the reported information isnt very useful. So unfortunately, "no change" doesn't really help us diagnose. The result on screen could be something different, but for all we know it's a new problem now.
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 2014-12-23 16:38:44.5597 Debug - ApiClient: Received 200 status code after 4.0002 ms from GET: http://192.168.1.67:8096/mediabrowser/Items/11bac755a2513142d136f0303b49804b/MediaInfo?UserId=bc85948b2977a395892cedb1189390b4&format=json2014-12-23 16:38:44.5997 Info - InternalDirectShowPlayer: Playing Alice: Through the Looking Glass. Audio Renderer: Default, Madvr: False, xySubFilter: True, ParentID: d67a10293ca973bf3794113d689a33982014-12-23 16:38:44.5997 Info - InternalDirectShowPlayer: Playing Path \\JASOON-PC\Movies\Alice Through the Looking Glass\Alice Through the Looking Glass.mp42014-12-23 16:38:44.5997 Debug - InternalDirectShowPlayer: IsFullScreen: W: 1440 H: 764 Top: 0 Bottom: 1080 Left: 0 Right: 19202014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: Configure LAV Splitter2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetSubtitleMode:2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetPGSForcedStream: True2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetPGSOnlyForced: False2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetVC1TimestampMode: Auto2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetSubstreamsEnabled: True2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetStreamSwitchRemoveAudio: False2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetUseAudioForHearingVisuallyImpaired: False2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetMaxQueueMemSize: 2562014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetTrayIcon: False2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetPreferHighQualityAudioStreams: True2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetLoadMatroskaExternalSegments: True2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetNetworkStreamAnalysisDuration: 10002014-12-23 16:38:46.1458 Debug - InternalDirectShowPlayer: NumberOfStreams: 12014-12-23 16:39:02.7728 Info - App: StartupTrigger fired for task: Log file cleanup2014-12-23 16:39:02.7728 Info - App: Executing Log file cleanup2014-12-23 16:39:02.7728 Info - App: Log file cleanup Completed after 0 minute(s) and 0 seconds2014-12-23 16:39:16.9306 Error - InternalDirectShowPlayer: Error adding LAV Video filter Server execution failed (Exception from HRESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILURE)) System.Runtime.InteropServices.COMException at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at System.Runtime.InteropServices.Marshal.ThrowExceptionForHR(Int32 errorCode) at System.Management.ManagementScope.InitializeGuts(Object o) at System.Management.ManagementScope.Initialize() at System.Management.ManagementObjectSearcher.Initialize() at System.Management.ManagementObjectSearcher.Get() at MediaBrowser.Theater.DirectShow.VideoConfigurationUtils.get_GpuModel() at MediaBrowser.Theater.DirectShow.DirectShowPlayer.RenderStreams(IBaseFilter pSource, Boolean enableMadvr, Boolean enableMadvrExclusiveMode, Boolean enableXySubFilter) 2014-12-23 16:39:16.9476 Debug - InternalDirectShowPlayer: Added default audio renderer2014-12-23 16:39:16.9476 Debug - InternalDirectShowPlayer: Add LAVAudio to the graph.2014-12-23 16:39:16.9476 Debug - InternalDirectShowPlayer: Enable LAVAudio Runtime Config
babgvant 143 Posted December 23, 2014 Posted December 23, 2014 2014-12-23 16:38:44.5597 Debug - ApiClient: Received 200 status code after 4.0002 ms from GET: http://192.168.1.67:8096/mediabrowser/Items/11bac755a2513142d136f0303b49804b/MediaInfo?UserId=bc85948b2977a395892cedb1189390b4&format=json 2014-12-23 16:38:44.5997 Info - InternalDirectShowPlayer: Playing Alice: Through the Looking Glass. Audio Renderer: Default, Madvr: False, xySubFilter: True, ParentID: d67a10293ca973bf3794113d689a3398 2014-12-23 16:38:44.5997 Info - InternalDirectShowPlayer: Playing Path \\JASOON-PC\Movies\Alice Through the Looking Glass\Alice Through the Looking Glass.mp4 2014-12-23 16:38:44.5997 Debug - InternalDirectShowPlayer: IsFullScreen: W: 1440 H: 764 Top: 0 Bottom: 1080 Left: 0 Right: 1920 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: Configure LAV Splitter 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetSubtitleMode: 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetPGSForcedStream: True 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetPGSOnlyForced: False 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetVC1TimestampMode: Auto 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetSubstreamsEnabled: True 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetStreamSwitchRemoveAudio: False 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetUseAudioForHearingVisuallyImpaired: False 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetMaxQueueMemSize: 256 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetTrayIcon: False 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetPreferHighQualityAudioStreams: True 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetLoadMatroskaExternalSegments: True 2014-12-23 16:38:45.9818 Debug - InternalDirectShowPlayer: SetNetworkStreamAnalysisDuration: 1000 2014-12-23 16:38:46.1458 Debug - InternalDirectShowPlayer: NumberOfStreams: 1 2014-12-23 16:39:02.7728 Info - App: StartupTrigger fired for task: Log file cleanup 2014-12-23 16:39:02.7728 Info - App: Executing Log file cleanup 2014-12-23 16:39:02.7728 Info - App: Log file cleanup Completed after 0 minute(s) and 0 seconds 2014-12-23 16:39:16.9306 Error - InternalDirectShowPlayer: Error adding LAV Video filter Server execution failed (Exception from HRESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILURE)) System.Runtime.InteropServices.COMException at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at System.Runtime.InteropServices.Marshal.ThrowExceptionForHR(Int32 errorCode) at System.Management.ManagementScope.InitializeGuts(Object o) at System.Management.ManagementScope.Initialize() at System.Management.ManagementObjectSearcher.Initialize() at System.Management.ManagementObjectSearcher.Get() at MediaBrowser.Theater.DirectShow.VideoConfigurationUtils.get_GpuModel() at MediaBrowser.Theater.DirectShow.DirectShowPlayer.RenderStreams(IBaseFilter pSource, Boolean enableMadvr, Boolean enableMadvrExclusiveMode, Boolean enableXySubFilter) 2014-12-23 16:39:16.9476 Debug - InternalDirectShowPlayer: Added default audio renderer 2014-12-23 16:39:16.9476 Debug - InternalDirectShowPlayer: Add LAVAudio to the graph. 2014-12-23 16:39:16.9476 Debug - InternalDirectShowPlayer: Enable LAVAudio Runtime Config Is the LAV video filter present? Do you have another version of LAV installed on the PC? if you regsvr32 lavvideo.ax from an admin command prompt does it regsister properly? If so, can you load the filter to a graph in GraphStudioNext? Do you have anti-virus SW installed? If so, which one? Are there any entries in the event log related to this error?
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 @@Luke @babgvant Could this be the issue? I seem to get the 200 status code when its trying to play video backdrops and also films 2014-12-23 16:56:04.1413 Debug - ApiClient: Received 200 status code after 146.0083 ms from GET: http://192.168.1.67:8096/mediabrowser/Items/892d39e30a5b8f710ee2cdb7e070b5f4/Images/Backdrop/2?Width=1920&Tag=ea1a3fd142fde6817e5558fce40f7f76&EnableImageEnhancers=True 2014-12-23 16:55:15.6285 Debug - ApiClient: GET http://192.168.1.67:8096/mediabrowser/Items/892d39e30a5b8f710ee2cdb7e070b5f4/Images/Primary?Width=550&Tag=47226736106deb8b40673295f9ae4745&EnableImageEnhancers=True2014-12-23 16:55:15.6895 Debug - ApiClient: Received 200 status code after 65.0037 ms from GET: http://192.168.1.67:8096/mediabrowser/Items/892d39e30a5b8f710ee2cdb7e070b5f4/Images/Primary?Width=550&Tag=47226736106deb8b40673295f9ae4745&EnableImageEnhancers=True2014-12-23 16:55:23.9140 Debug - ApiClient: GET http://192.168.1.67:8096/mediabrowser/Items/892d39e30a5b8f710ee2cdb7e070b5f4/Images/Backdrop/1?Width=1920&Tag=6f0c13207ff1667da25cc1d2a86e675d&EnableImageEnhancers=True2014-12-23 16:55:23.9140 Debug - ApiClient: Received 200 status code after 6.0003 ms from GET: http://192.168.1.67:8096/mediabrowser/Items/892d39e30a5b8f710ee2cdb7e070b5f4/Images/Backdrop/1?Width=1920&Tag=6f0c13207ff1667da25cc1d2a86e675d&EnableImageEnhancers=True
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 Is the LAV video filter present? I have LAVVideo.ax in the COMobjects folder Do you have another version of LAV installed on the PC? Ive tried it with LAV installed on my pc and also with it removed if you regsvr32 lavvideo.ax from an admin command prompt does it regsister properly? If so, can you load the filter to a graph in GraphStudioNext? when I tried to regsvr32 lavvideo.ax I get an error "the module "lavvideo.ax" failed to load. Make sure the binary is stored at the specified path Do you have anti-virus SW installed? If so, which one? I have webroot anti-virus installed Are there any entries in the event log related to this error? The main error in the MBT log is 2014-12-23 16:55:44.3621 Info - App: Cache file cleanup Completed after 0 minute(s) and 0 seconds2014-12-23 16:55:45.2412 Error - InternalDirectShowPlayer: Error adding LAV Video filter Server execution failed (Exception from HRESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILURE)) System.Runtime.InteropServices.COMException at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at System.Runtime.InteropServices.Marshal.ThrowExceptionForHR(Int32 errorCode) at System.Management.ManagementScope.InitializeGuts(Object o) at System.Management.ManagementScope.Initialize() at System.Management.ManagementObjectSearcher.Initialize() at System.Management.ManagementObjectSearcher.Get() at MediaBrowser.Theater.DirectShow.VideoConfigurationUtils.get_GpuModel() at MediaBrowser.Theater.DirectShow.DirectShowPlayer.RenderStreams(IBaseFilter pSource, Boolean enableMadvr, Boolean enableMadvrExclusiveMode, Boolean enableXySubFilter) 2014-12-23 16:55:45.2532 Debug - InternalDirectShowPlayer: Added default audio renderer
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 @babgvant this is a screen grab of what happened when I tried to regsvr32 lavvideo.ax https://dl.dropboxusercontent.com/u/73415573/lavvideo.ax.PNG
babgvant 143 Posted December 23, 2014 Posted December 23, 2014 if you regsvr32 lavvideo.ax from an admin command prompt does it regsister properly? If so, can you load the filter to a graph in GraphStudioNext? when I tried to regsvr32 lavvideo.ax I get an error "the module "lavvideo.ax" failed to load. Make sure the binary is stored at the specified path Just to make sure, you ran regsvr32 "c:\programdata\...\COMObjects\LAV\lavvideo.ax"? If so, there should be an event in the Event Log about why. Are there any entries in the event log related to this error? The main error in the MBT log is 2014-12-23 16:55:44.3621 Info - App: Cache file cleanup Completed after 0 minute(s) and 0 seconds ... 2014-12-23 16:55:45.2532 Debug - InternalDirectShowPlayer: Added default audio renderer Sorry, I meant the Windows Event Log (aka Event Viewer). above
babgvant 143 Posted December 23, 2014 Posted December 23, 2014 @babgvant this is a screen grab of what happened when I tried to regsvr32 lavvideo.ax https://dl.dropboxusercontent.com/u/73415573/lavvideo.ax.PNG 404
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 Ive managed to register lavvideo.ax using the command prompt still getting the InternalDirectShowPlayer: Error adding LAV Video filter in MBT log I have no idea as to what to look for in Event Viewer
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 fund this in event viewer at about the same time as im trying to play a video Log Name: SystemSource: Service Control ManagerDate: 23/12/2014 17:10:56Event ID: 7023Task Category: NoneLevel: ErrorKeywords: ClassicUser: N/AComputer: Jasoon-PCDescription:The Windows Management Instrumentation service terminated with the following error:The system cannot find the file specified.Event Xml:<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" /> <EventID Qualifiers="49152">7023</EventID> <Version>0</Version> <Level>2</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x8080000000000000</Keywords> <TimeCreated SystemTime="2014-12-23T17:10:56.527604100Z" /> <EventRecordID>688957</EventRecordID> <Correlation /> <Execution ProcessID="712" ThreadID="77116" /> <Channel>System</Channel> <Computer>Jasoon-PC</Computer> <Security /> </System> <EventData> <Data Name="param1">Windows Management Instrumentation</Data> <Data Name="param2">%%2</Data> </EventData></Event>
babgvant 143 Posted December 23, 2014 Posted December 23, 2014 Ive managed to register lavvideo.ax using the command prompt still getting the InternalDirectShowPlayer: Error adding LAV Video filter in MBT log I have no idea as to what to look for in Event Viewer Can you load LAVVideo in GraphStudioNext? Look for anything indicating an error/warning, if there isn't one then nothing is getting logged.
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 I could only load LAVVideo in GraphStudioNext when I install LAV as a stand alone instilation
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 if I try and manually add LAVVideo in GraphStudioNext I get an error No CLSID provided
babgvant 143 Posted December 23, 2014 Posted December 23, 2014 if I try and manually add LAVVideo in GraphStudioNext I get an error No CLSID provided So LAV is registered (you can see it in the DS filter list in GSN), but when you try to add it GSN gives that error?
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 the only way to get it in the DS filter list was to do a stand alone install of LAV, when I direct it to the one in MBT I get the No CLSID provided error in GSN
Solution babgvant 143 Posted December 23, 2014 Solution Posted December 23, 2014 fund this in event viewer at about the same time as im trying to play a video Log Name: System Source: Service Control Manager Date: 23/12/2014 17:10:56 Event ID: 7023 Task Category: None Level: Error Keywords: Classic User: N/A Computer: Jasoon-PC Description: The Windows Management Instrumentation service terminated with the following error: The system cannot find the file specified. Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" /> <EventID Qualifiers="49152">7023</EventID> <Version>0</Version> <Level>2</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x8080000000000000</Keywords> <TimeCreated SystemTime="2014-12-23T17:10:56.527604100Z" /> <EventRecordID>688957</EventRecordID> <Correlation /> <Execution ProcessID="712" ThreadID="77116" /> <Channel>System</Channel> <Computer>Jasoon-PC</Computer> <Security /> </System> <EventData> <Data Name="param1">Windows Management Instrumentation</Data> <Data Name="param2">%%2</Data> </EventData> </Event> I missed this before: at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at System.Runtime.InteropServices.Marshal.ThrowExceptionForHR(Int32 errorCode) at System.Management.ManagementScope.InitializeGuts(Object o) at System.Management.ManagementScope.Initialize() at System.Management.ManagementObjectSearcher.Initialize() at System.Management.ManagementObjectSearcher.Get() The error is coming from WMI (what System.Management wraps). Something is messed with WMI. Any chance you are running Windows 7 and have KB3004394 installed? 1
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 @babgvant Yes im on windows 7 and Yes I have KB3004394 installed
