Jasoon 9 Posted December 20, 2014 Posted December 20, 2014 Is there a way to access the LAV settings from with in MBT? Im sure there used to be but I cant seem to access it now
Luke 42239 Posted December 21, 2014 Posted December 21, 2014 the only settings you need in MBT are available within the application
Jasoon 9 Posted December 21, 2014 Author Posted December 21, 2014 (edited) are any of the LAV settings available with in MBT? Edited December 21, 2014 by Jasoon
Jasoon 9 Posted December 21, 2014 Author Posted December 21, 2014 Luke im sure I used to be able to access the LAV setting from the settings in MBT, but now I cant...
Luke 42239 Posted December 21, 2014 Posted December 21, 2014 because it's not needed anymore. the only settings you need in MBT are available within the application
Jasoon 9 Posted December 21, 2014 Author Posted December 21, 2014 Is this all I should have access to?
Jasoon 9 Posted December 21, 2014 Author Posted December 21, 2014 https://dl.dropboxusercontent.com/u/73415573/Capture%20LAV.PNG
Jasoon 9 Posted December 21, 2014 Author Posted December 21, 2014 Luke im still having this issue:- Error - InternalDirectShowPlayer: Error adding LAV Video filter Server execution failed (Exception from HRESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILURE)) System.Runtime.InteropServices.COMException
Della Dog 19 Posted December 21, 2014 Posted December 21, 2014 (edited) because it's not needed anymore. the only settings you need in MBT are available within the applicationWhat Luke is saying, in a not so diplomatic way, is that most of the LAV configuration settings are found in the MBT settings section. When you change the settings in MBT, what you are actually doing is changing the underlying LAV settings. I'm not a fan of hiding LAV configuration from the user, it confuses most who are familiar with LAV, it is not all inclusive & sometimes the changes don't "stick." In my opinion, LAV should remain a stand alone installation. Edited December 21, 2014 by Della Dog
DingDong 0 Posted December 21, 2014 Posted December 21, 2014 What Luke is saying, in a not so diplomatic way, is that most of the LAV configuration settings are found in the MBT settings section. When you change the settings in MBT, what you are actually doing is changing the underlying LAV settings. I'm not a fan of hiding LAV configuration from the user, it confuses most who are familiar with LAV, it is not all inclusive & sometimes the changes don't "stick." In my opinion, LAV should remain a stand alone installation. I agree 100%...the settings don't stick!!!!
Jasoon 9 Posted December 22, 2014 Author Posted December 22, 2014 There doesn't appear to be any LAV settings available at all in MBT, when I change video render all I have is EVR, EVR+ and madVR Filter set there's only Edge or Stable. If I then go onto Configure Video Renderer there's only madVR settings in there.... Im having an issue where it takes ages for videos to play once they have been selected in MBT. Looking at my logs I get a message about an Error adding LAV Video filter, but im not sure if I should get this error or if this is what's causing the delay.. I managed to get rid of the delay by putting the filter set to Edge but now the delay has returned and I cant get it to work properly...
Jasoon 9 Posted December 22, 2014 Author Posted December 22, 2014 In my log I seem to have thins :- 2014-12-21 20:04:43.2537 Debug - InternalDirectShowPlayer: IsFullScreen: W: 1920 H: 1080 Top: 0 Bottom: 1080 Left: 0 Right: 19202014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: Configure LAV Splitter2014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetSubtitleMode:2014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetPGSForcedStream: True2014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetPGSOnlyForced: False2014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetVC1TimestampMode: Auto2014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetSubstreamsEnabled: True2014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetStreamSwitchRemoveAudio: False2014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetUseAudioForHearingVisuallyImpaired: False2014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetMaxQueueMemSize: 2562014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetTrayIcon: True2014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetPreferHighQualityAudioStreams: True2014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetLoadMatroskaExternalSegments: True2014-12-21 20:04:43.2717 Debug - InternalDirectShowPlayer: SetNetworkStreamAnalysisDuration: 10002014-12-21 20:04:43.4727 Debug - InternalDirectShowPlayer: NumberOfStreams: 12014-12-21 20:04:44.0017 Info - App: StartupTrigger fired for task: Log file cleanup2014-12-21 20:04:44.0017 Info - App: Executing Log file cleanup2014-12-21 20:04:44.0017 Info - App: Log file cleanup Completed after 0 minute(s) and 0 seconds2014-12-21 20:05:13.5004 Error - InternalDirectShowPlayer: Error adding LAV Video filter Server execution failed (Exception from HRESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILURE)) System.Runtime.InteropServices.COMException at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at System.Runtime.InteropServices.Marshal.ThrowExceptionForHR(Int32 errorCode) at System.Management.ManagementScope.InitializeGuts(Object o) at System.Management.ManagementScope.Initialize() at System.Management.ManagementObjectSearcher.Initialize() at System.Management.ManagementObjectSearcher.Get() at MediaBrowser.Theater.DirectShow.VideoConfigurationUtils.get_GpuModel() at MediaBrowser.Theater.DirectShow.DirectShowPlayer.RenderStreams(IBaseFilter pSource, Boolean enableMadvr, Boolean enableMadvrExclusiveMode, Boolean enableXySubFilter) 2014-12-21 20:05:13.5544 Debug - InternalDirectShowPlayer: Added default audio renderer2014-12-21 20:05:13.5544 Debug - InternalDirectShowPlayer: Add LAVAudio to the graph.2014-12-21 20:05:13.5544 Debug - InternalDirectShowPlayer: Enable LAVAudio Runtime Config2014-12-21 20:05:13.5544 Debug - InternalDirectShowPlayer: Enable LAVAudio S/PDIF bitstreaming2014-12-21 20:05:13.5544 Debug - InternalDirectShowPlayer: Enable LAVAudio HDMI bitstreaming Looking at someone else's log they get :- 2014-12-21 10:58:14.5237 Debug - InternalDirectShowPlayer: SetUseAudioForHearingVisuallyImpaired: False 2014-12-21 10:58:14.5237 Debug - InternalDirectShowPlayer: SetMaxQueueMemSize: 256 2014-12-21 10:58:14.5237 Debug - InternalDirectShowPlayer: SetTrayIcon: True 2014-12-21 10:58:14.5237 Debug - InternalDirectShowPlayer: SetPreferHighQualityAudioStreams: True 2014-12-21 10:58:14.5237 Debug - InternalDirectShowPlayer: SetLoadMatroskaExternalSegments: True 2014-12-21 10:58:14.5237 Debug - InternalDirectShowPlayer: SetNetworkStreamAnalysisDuration: 1000 2014-12-21 10:58:14.8718 Debug - ApiClient: GET http://192.168.1.139...eEnhancers=True 2014-12-21 10:58:16.1138 Debug - ApiClient: Received 200 status code after 1242.071 ms from GET: http://192.168.1.139...eEnhancers=True 2014-12-21 10:58:16.9099 Info - App: StartupTrigger fired for task: Cache file cleanup 2014-12-21 10:58:16.9099 Info - App: Executing Cache file cleanup 2014-12-21 10:58:16.9099 Info - App: Cache file cleanup Completed after 0 minute(s) and 0 seconds 2014-12-21 10:58:18.0769 Debug - InternalDirectShowPlayer: NumberOfStreams: 1 2014-12-21 10:58:18.3880 Debug - InternalDirectShowPlayer: GPU Model: Intel® HD Graphics 4000 2014-12-21 10:58:18.3880 Debug - InternalDirectShowPlayer: Current HWA Mode: None Desired Mode: QuickSync 2014-12-21 10:58:18.3880 Debug - InternalDirectShowPlayer: Disable HWA support for: MPEG2DVD 2014-12-21 10:58:18.4570 Error - InternalDirectShowPlayer: Error adding WASAPI audio filter Retrieving the COM class factory for component with CLSID {EC9ED6FC-7B03-4CB6-8C01-4EABE109F26B} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)). System.Runtime.InteropServices.COMException at MediaBrowser.Theater.DirectShow.URCOMLoader.GetObject(KnownCOMObject kf, Boolean comFallback) at MediaBrowser.Theater.DirectShow.URCOMLoader.GetObject(Guid guid, Boolean comFallback) at MediaBrowser.Theater.DirectShow.DirectShowPlayer.RenderStreams(IBaseFilter pSource, Boolean enableMadvr, Boolean enableMadvrExclusiveMode, Boolean enableXySubFilter) 2014-12-21 10:58:18.4570 Debug - InternalDirectShowPlayer: Added default audio renderer 2014-12-21 10:58:18.4740 Debug - InternalDirectShowPlayer: Add LAVAudio to the graph. 2014-12-21 10:58:18.4740 Debug - InternalDirectShowPlayer: Enable LAVAudio Runtime Config
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 @@Luke Been chatting to fantaxp7 and i dont have the same options in MBT as he dose... How do i get someone to have a look into the issues im having? it seems as if LAV dosnt want to play ball
Luke 42239 Posted December 23, 2014 Posted December 23, 2014 then try reinstalling the latest from the website. or ask him to reinstall.
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 Ive tried re-sinstaling no change...
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 @@Luke ive also tried turning on guist account and installing it under guest account and i get the same issue
Luke 42239 Posted December 23, 2014 Posted December 23, 2014 as long as you have settings under Settings -> video Player, then you have everything you need to configure MBT. I am not sure what your'e expecting here. It seems like you just keep asking the same question differently hoping for a different answer, but the outcome is the same. i guess the question would be what particular setting are you looking for so that in the event one is missing it can be added.
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 @@Luke if thats the case can you help track down why i keep getting Error adding LAV Video filter i have a large delay when i select a film to play before it plays, same goes for video backdrops, it used to be more or less instant... Is there an arcive of MBT so i can go back to a earlier version?
Luke 42239 Posted December 23, 2014 Posted December 23, 2014 I've sent a note to babgvant asking him to take a look at this.
Jasoon 9 Posted December 23, 2014 Author Posted December 23, 2014 @@Luke I take it this is the delay 2014-12-21 20:04:44.0017 Info - App: Log file cleanup Completed after 0 minute(s) and 0 seconds2014-12-21 20:05:13.5004 Error - InternalDirectShowPlayer: Error adding LAV Video filter ~29 seconds but im not sure how to sort it
Luke 42239 Posted December 23, 2014 Posted December 23, 2014 babgvant - when you see this, he started out asking for lav settings in the beginning of the thread, but the root issue is actually the long delay when playing as well some failures in the log.
babgvant 143 Posted December 23, 2014 Posted December 23, 2014 Please try deleting the COMObjects folder in the MBT config folder. MBT should download LAV (and all the filters it needs) automatically. There maybe an issue with the updating process (it's hard to test all the permutations).
