Tranquil 95 Posted December 20, 2014 Posted December 20, 2014 Hi Devs. With the latest Update I'm no longer able to do a search on my media. If i click the magnifier nothing happens.
DrWatson 62 Posted December 21, 2014 Posted December 21, 2014 Red is already aware of this and will put out a fix soon.
Redshirt 1487 Posted December 21, 2014 Posted December 21, 2014 I'm looking into it, but a fix will not be in todays update.
Redshirt 1487 Posted December 22, 2014 Posted December 22, 2014 Those or you that are having issues with search. Does it work if the icon is directly on the Action Bar on 2.1.34? I've discovered it doesn't work if it's in the overflow menu, but does work on the Actionbar.
Tranquil 95 Posted December 22, 2014 Author Posted December 22, 2014 I'm now on 2.1.34 and I'm able to do searches by the action bar. Cant find a menu entry any longer to start a search on my GT I9506 but that is not a problem.
Redshirt 1487 Posted December 22, 2014 Posted December 22, 2014 That's good. Once I get feedback from one tester that's affected, I can consider this fixed.
