markrobbo78 0 Posted December 18, 2014 Posted December 18, 2014 Scan media library failed. 3 minutes ago Start index cannot be less than 0 or greater than input length. Parameter name: start Each time I run Media Library Scan I am getting an error and the scan fails with the above error being displayed. This appears to have coincided with updating the version of the server. I am running Version 3.0.5464.40000 I have attached the log file - would appreciate any insight you can give me. Cheers, Mark Log_Server_ScanLibraryError.txt
Luke 42184 Posted December 18, 2014 Posted December 18, 2014 can you post a screenshot of the contents of this folder? \\nas-markrobbo78\Videos\INDEX HTPC\Movies\Watched\3 - ACTION\Argo (2012) thanks
markrobbo78 0 Posted December 19, 2014 Author Posted December 19, 2014 Hi Luke, Thanks for the tip - found some rar files in that folder - took the screengrab for you but also thought I'd try removing them. Sure enough, soon as they were removed, scan completed per normal. Thanks for pointing me in the right direction. Cheers, Mark
Mark.S 0 Posted December 30, 2014 Posted December 30, 2014 can you post a screenshot of the contents of this folder? \\nas-markrobbo78\Videos\INDEX HTPC\Movies\Watched\3 - ACTION\Argo (2012) thanks Hi Luke - I have just started receiving the same issue. I've been updating a lot of metadata recently, but not sure of the exact error path. Log file is attached. Thanks in advance. server-63555618650.txt
Happy2Play 9798 Posted December 31, 2014 Posted December 31, 2014 The log appears to point to D:\Formula 1 Season Review - All Seasons\F1 2009 Season Review (2009). 2014-12-31 10:30:59.6032 Error - App: Error in MovieResolver resolving D:\Formula 1 Season Review - All Seasons\F1 2009 Season Review (2009)
Luke 42184 Posted December 31, 2014 Posted December 31, 2014 this should be resolved for the next release
Mark.S 0 Posted December 31, 2014 Posted December 31, 2014 The log appears to point to D:\Formula 1 Season Review - All Seasons\F1 2009 Season Review (2009). 2014-12-31 10:30:59.6032 Error - App: Error in MovieResolver resolving D:\Formula 1 Season Review - All Seasons\F1 2009 Season Review (2009) Thanks - Checked the folder, multiple files with the same name, but different extension as I was handbraking a file. Thanks again for the quick response.
